Click for Westport Click for Burger Click for Delta Click for Burger Click for Abeking
Boat buying process through a broker
Discussion in 'Carver Yacht' started by cdwenrick, Oct 3, 2013.
  1. cdwenrick
    cdwenrick New Member
    Cape May
    I am settling on my boat search to a 2000 Carver 396 through a broker. Spending this much, using a broker, and having a seatrial and survey are new experiences for me and I have several questions: (I bought my last boat from an acquaintance, for a lot less money, so I didn't do these things)
    -Is it common to have to sign the contract before you even can give an offer on the boat?
    -Are there standard broker contracts to review as I have questions on mine? It makes me nervous with all of the language protecting the broker.
    -Should you use an attorney for the contract and even for the close? If so, what kind of price is reasonable?
    -Is the duration to sign the contract normally only two days for the buyers's and seller's to sign?
    Cliff
    PS: I had posted previously with questions about Carver 396/366/346 & 36 SS
  2. bliss
    bliss Senior Member
    Racine
    WOW! First query - NO! There are many "Standard" broker contracts. What you are seeing (if they gave you a copy) is a contract written in favor of an attorney's clent - AND THATS NOT YOU. If you want to make an offer take that contract and make any reasonabble changes by striking out and changing with pen and initial. What happens if certain contingences occur - your death or disablility, etc? put them all in; they can be taken out later. It is a negotiation! Second - Sure but are you going to chase them all down? Ask a couple of brokers in your area to share with you. Again, you have pen, use it. Third. Attorney? Maybe. If you remain uncomfortible. Check around. Fourth Price - Who knows. Look at the market - very broad view - yachts lag the real estate market by a considerable margin, both up and down. I think the yacht market has a lot of catching up left. So look at the line of buyers behind you. WHAT! Nobody there!!! Make an offer. What can the seller do! Worst - say "Go pound sand." So what. Move up or move on. Fifth: Ten days or who cares? They are trying to apply pressure. They can't unless they have leverage -like the boat is gold plated, etc.
    Lastly, I am very familiar with that boat. It is a dandy aft cabin. Good Luck!
  3. NYCAP123
    Good answer, but let me expand on what you said at the start. It's pretty normal for a broker to show a boat once, maybe twice. Before sea trial and survey, and maybe any more looks, it's time to negotiate (prepared to make an immediate deposit), sign contracts and place deposits 'conditional on satisfactory survey, sea trial and......'
  4. bliss
    bliss Senior Member
    Racine
    NYC, are you saying that when a prospect wants a third or fourth look the broker might ask for or insist on a contract first? Well maybe. I guess that would be a judgement call depending on the broker's evaluation of the prospect. I can imagine what an awful day a broker has when "entertaining" non-prospects - up and down the ladder ----.
    As an aside; I try to find what I want direct - me and the seller. However, I always pay a broker to sell. Just me and my way; and the fact that I have no patience with tire kickers. That is NOT a knock on brokers. The good ones earn every nickel.
  5. NYCAP123
    It's one thing when you're looking at a boat at a dealership, but many times the broker may travel from another section of the country, spending money and a whole day. Then, when negotiations get to the impass point, they're likely to give up some of their commission to make the deal work. They only want to talk with you when they know you're serious.
    If you can find an FSBO you have the potential to cut deeper in your negotiations since they're not paying commission, but often you can actually do better with a 3rd party who'll tell the seller the offer's good.
  6. Pascal
    Typically, a buyer will look at at boat a couple of times before making a decision although it should be just fine to look at a boat 3 to 4 times before making an offer. It all comes down to how serious a buyer you look to the broker
    You said "through a broker" but I m not sure whether you are talking about using your own buyers broker which is a good option, at no cost to you, at you have someone on your side representing you. When you are only dealing with the sellers broker, he is not representing you, but his client the seller. The only downside to using a buyers broker is that a few boats may not be available as sometimes some brokers do not want to split. It is pretty rare so usually not a real issue.
    After you see the boat and decide to make an offer, you will sign a contract with a small deposit which will be presented to the seller for acceptance. The time frame is typically a couple of days during which the seller can reject, accept, counter offer, or just ignore. The contract will include a few important conditions incl. sea trial and survey, insurability and ability to get financing If applicable as well as closing date.
    I always prefer to do a separate sea trial before survey. This is important to make sure the boat is worth surveying, performs as expected, etc. Some people just do one sea trial during survey which is ok if everything goes fine. But the boat doesn't run well, runs hot, has a vibration or has issue, you may be out a couple of thousand dollars for survey costs just to be told the obvious.
    Survey should include both hull and machinery, which on a diesel will require two surveyors.
    During survey and sea trial, the seller is responsible to run the boat, or provide a captain to run it, and will cover the fuel costs. You are responsible for paying the short haul at a yard for the surveyor to inspect the hull
    If the offer is accepted, you give th full deposit, usually around 10% which is held by the broker. This is where having your own broker is a plus as he will hold the deposit which if something goes wrong may easier to recover than from the sellers broker. Obviosuly both brokers will follow the rules but a sellers broker may drag his feet a little...
    Closing time frame is usually around a month with set dates for sea trial and survey acceptance.
    If during the initial sea trial you are not satisfy with the boat performance, mechanical condition or handling, you will be able to back out. If survey turns out items which are serious enough to cause you to back out, you will be able to do so with no penalty.
    After survey, you have the option to accept the boat as it is, request that the seller makes repairs or adjust the selling price. Surveys always turn up some minor issues and you re not going haggle over them... At that point you are already out the cost of the survey and have less leverage. More serious issues will be subject to negotiation and your surveyor s advice will be important at this point. If an issue is simple and clear cut, say a GPS not working, it may be easier to negotiate a price adjustment. If something is more complex then you may want to ask the seller to fix it and check the outcome before committing. For instance, if the boat doesn't turn rated rpm or runs not it may be hard to be sure of the cause and of th cost. In that case, have the seller do the repair to be sure a $1000 repair doesn't turn into $10 000 on your dime.
    After surveys are done, you sign a letter of acceptance and move to closing
    To answer your other questions, contracts are not always completely standard, read it carefully. Usually, for a boat that size you probably don't need an attorney but if you don't feel comfortable then yes seek advice. With a buyers broker you are less likely to need an attorney as again the buyers broker works for you, not the seller.
  7. JWY
    JWY Senior Member
    Much good advice given. A few additional comments:
    The "standard" contracts are ones used by professional brokers who are members of yachting organizations such as FYBA (Florida Yacht Brokers Assoc.), CYBA, etc. Boats US also has one I believe.
    A client needs to see a vessel as many times as he wants until he is sure that he wants to make an offer. I have never heard of a "see xtimes to purchase" ratio.
    A lawyer should not be necessary if dealing with reputable and experienced brokers. Do research on the broker; s/he shouldn't mind giving you information on escrow account, references, etc.
    Judy
    Pascal- I agree with all of your info except the pre-survey seatrial. Very very rarely will a seller agree to that as it would cost the seller an easy $1000 (on a 50') or more for that between paying a Captain and maybe a mate depending on size, rinsing/chamoising it when it gets back, the fuel, etc etc...... If the buyer offered to cover the cost of that, then the seller would probably agree but they don't usually.
  9. SeaEric
    SeaEric YF Historian
    out on the dock
    I agree. In addition to the added cost, its unfair to expect that a boat that has perhaps been sitting for a while will perform properly without first being hauled and bottom and running gear cleaned and inspected.
  10. hapesjr
    hapesjr New Member
    Bellingham, WA
    Buying Broker w/ independent seller
    I was selling my boat and a broker wanted to bring me a buyer w/ a qualifying offer, but wanted me to sign a "referral agreement" first giving him 10% if the deal goes through. is this common?
  11. olderboater
    Somewhat. Most brokers don't follow privately for sale boats, but if someone wants something he can't find, he may. Still, it's not out of the goodness of his heart.
  12. hapesjr
    hapesjr New Member
    Bellingham, WA
    I don't imagine, so. I understand everyone needs to make a buck, but should I pay a listing fee for essentially having a buyer brought to me?
  13. olderboater
    Do you want the buyer? Of course you can try to negotiate.
  14. bliss
    bliss Senior Member
    Racine
    OlderB is right. Why say "No" when saying "5%". takes just about the same amount of breath. "Trust but verify". Who is this guy? Who knows him? Is he associated with quality people? Etc., etc. If he won't leave his agreement with you overnight WALK. Good luck!
  15. olderboater
    And don't let him trick you into a general agreement by using "I have a buyer" scheme. Make sure you sign just for the single buyer.
  16. Capt J
    Isn't that precisely what a Yacht Broker does for a living? If he already has a client that wants your boat and he approached you, pay him 5% which is what he'd split if there was a 2nd broker/house involved.
  17. Pascal
    Well th few deals I ve been involved with, my own boats and customers, doing a pre survey sea trial was not a problem. Owner/seller usually ran the boat and fuel costs are minimal, you re talking about a 10' on plane and whatever it takes to get out to an open area. On a 50 to 80 footer, you re talking 40 gallons of fuel at the most.
    What I think is unfair is a seller hoping to sell a boat which has been sitting and hoping some sucker comes along and pay for short haul to clean the bottom... :) so yes, I expect to see a boat that s in working order before I spend $3 to $5k on survey and short haul.
    Why is the boating industry some different from the real world... Imagine realtor telling sellers "don't cut the grass, the buyer will after closing"
    Now, I guess when you get over 80' the costs of the short sea trial become higher but even then it would be like getting some engine work done and telling the mechanic there will be no sea trial to save a buck. Then on the bigger boat the crew is usually full time so crew cost and clean up isn't an issue
  18. RER
    RER Senior Member
    Newport Beach CA
    That's right on the money. A reputable broker will take a split commission on that kind of deal. Didn't have to list it, advertise it, show it 47 times, etc. Broker represents buyer, and seller takes the place of listing broker so he saves that portion of the commission.
  19. JWY
    JWY Senior Member
    Yes, but... If the broker has one of his/her Central Listings that is appropriate, then the broker will make a 10% commission, so why should the broker make less on an alternative boat? Now, if the broker doesn't have anything else appropriate or if the buyer directed the broker to this particular vessel, then circumstances may be different. Also, is the broker being used as "Buyer's Broker" for their expertise and opinions? I'm not sure I agree that the commission due is always based on the number of showings and $$ spent on advertising. An "easy" deal still take time, knowledge, responsibility, and expertise and makes up for the zillions of clients that end up without compensation.
    If the owner has it FSBO and hasn't sold it and a broker brings a qualified buyer, then he's done his job and is deserving of the full commission. The bottom line is the broker got the job done that no one else did.
  20. olderboater
    It's really no different than selling a home. FSBO can save money but the vast majority require brokers and, while fees are negotiable, with lower commissions often come less professionalism or effort. Brokers do more than bring buyers to you. They qualify that buyer, they help in the contractual and paperwork side of things, help arrange surveys, they help find financing. While there may be times to negotiate reduced commissions (perhaps you just put on market and already had it priced for quick sale and a firm price plus no other broker services required), in most cases the full commission is earned. How much did the broker spend on advertising, which while not advertising your boat, did get the buyer to them?
