Click for Burger Click for Walker Click for Glendinning Click for Ocean Alexander Click for Cross
A/C Installation Question - 32 Carver Mariner
Discussion in 'Carver Yacht' started by wxb167, Jun 11, 2019.
  1. wxb167
    wxb167 Guest
    Hello:
    I have a 32 Carver Mariner and I would like to install an a/c unit, however, I can't seem to find out - where do you root the water line from the pump to the a/c unit?
    Any assistance is appreciated.
    Thanks,
    Ian
  2. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    Do you have a thru hull for the supply to the a/c pump?
  3. wxb167
    wxb167 Guest
    Yes, I do.
  4. wxb167
    wxb167 Guest
    I have a thru hull pickup with a seacock to shut it off.
  5. Poppa John
    Poppa John New Member
    Naples Florida
    Is the thru hull located in the floor hatch in front of the refrigerator ? Where is the pump ? And where is the A/C unit ?
  6. Pascal
    To avoid priming problem make sure the pump is close to the seacock without any high or low point in the hose. The pump must be below waterline. From the pump outlet on, high and low points aren’t critical but if you have any before the pump it will airlock
  7. DoubleTrouble
    DoubleTrouble New Member
    League City Tx
    The hose goes through the side on the starboard side of the galley access. It goes under the floor of the sink cabinet and pops up there. On mine I have a divider to keep you from electricity when you reach under the sink. It pops up in after that
  8. DoubleTrouble
    League City Tx
    If you have two seacocks in the access panel which side is connected to the head? Port or starboard?
