Click for Delta Click for Northern Lights Click for Burger Click for Perko Click for Burger
42 post prop size
Discussion in 'Post Yacht' started by Gambetica, Oct 4, 2016.
  1. Gambetica
    Gambetica Member
    Venezuela
    Hi, i have a post 1978 42", not doing so well in cruise speed, what size you recommend on props? 3 or 4 blades?
    Right now i have 24/24, 3 blades, and at maximun rpm uits ginig 2500 RPM, @1900 cruise speed, 11 knots, 2300 14 knots, 2500 17 knots.
    Our injector n-65.
    regards Juan
  2. baltimore bob
    baltimore bob Member
    Baltimore, Maryland
    Hmmm, that don't sound right. If they are J&T 6-71s they should have n 80 injectors. I'm running 14X28 four blade props and get 23 knots @2350 on my 1975 42.
  3. Gambetica
    Gambetica Member
    Venezuela
    Yes they are 671-N, but I saw the original specs and recommend N-65
  4. OutPost
    OutPost Member
    Long Island, New York
    I assume hull is clean - when was last time the existing props were scanned and conditioned? Do you have any historical reference points (old owner statements, old surveys, etc) that may show if this is a recent development or how long it's been running at these speeds?
    My new to me 42 is a gasser so hard to compare, but it's a little slower than some other gassers I've managed to locate and find info on (not too many). She also doesn't turn up to top RPMs as she should - going to have props reconned over winter and possibly a little pitch reduced.
    Good luck - you should definitely be cruising at least 16 if not more. (In neutral current).
  5. baltimore bob
    Baltimore, Maryland
    I need a picture of those engines. To my knowledge the only 6 71 n package was the 310 HP from Johnson & Towers. They would have N08s, I'm looking at the J&T spec sheet.
  6. RT46
    RT46 Senior Member
    Sometimes boats accumulate so much stuff over time that all the stuff adds substantial weight.
    I read a good suggestion (on this site I think):
    Go through the boat once a year, if its not safety equipment and you haven't used it in a year, get the extra stuff off the boat!
  7. My Affair
    My Affair Member
    Mystic, CT
    The 1975 42', hull #11- I just sold had 6-71 naturals. She has nibral 24x25 with medium cup Federal 4 blades on her. At sea trial she did 22 knots at 2550, at 2350 cruise 17-18.
