Click for Walker Click for Delta Click for Ocean Alexander Click for Nordhavn Click for Northern Lights
1993 chris craft 380 continental performance question
Discussion in 'Chris Craft Connies, Commanders & Catalinas' started by flboater, Jul 7, 2012.
  1. flboater
    flboater New Member
    Miami Florida
    Hello,
    I recently purchased a '93 ChrisCraft 380 Continental. The boat had 454 gas engines which were in poor condition so I changed them with some Yanmar 6 lps. I am trying to get the proper propellers but am not sure what speed this boat cruises at. I see a published speed of 15 knots but I see people say they cruise closer to the 25 knot range (or higher). By chance, do any of you have a similair Chris Craft and if so what kind of performance do you get? I currently have 3-blade 20X18 props which give me the correct WOT rpm of 3900 but at 3400 rpm she seems slow at aroudn 14 knots (fully loaded) and also seems she is not able to trim out properly.
    You may always see 3900 rpm because of the Governor. I think you are under propped. Do you have fuel flow info? Do you have access to some loaner wheels of larger pitch to try? I assumed you stayed close to the LBG gear ratio.
    The 6LP may be just under powered replacing a large block gas motor, the weight savings may make up for some of your calculations.
    I hope you have contacted Yanmar support before, during and still now on your performance expatiations also. Have they made any comments?
  3. flboater
    flboater New Member
    Miami Florida
    Thanks for the reply and of course you rasie valid points. I do not have access to fuel flow. I tried a larger set of props (I think they were 20 X 20?) that were 4 blade and while I got a better speed - 20 knts at 3400 rpm, I could not get to the 3900 rpm at WOT and that is certianly the "magic number".
    The Yanmars are 300 hp and they replaced 330 hp gas engines so while I lost 10% HP I almost doubled torque. I am in contact with several people such as Yanmar and a local prop shop. In both cases I need to give them an idea of how fast the boat should go and that is where I am hitting a wall. I never knew what the boat with the gas engines ran at and I am seeing posted values of 15 knts to 30 knts cruising speeds. My thought is that at 14 to 15 the boat is not ableto trim properly and this is reducing my rpms.If I can increase the speed to around 25 knts I would be "surfing" the wave instead of trying to go up it and this could mean that I can get my 3900 rpm with a higher pitched prop.
    Did you stay with the gas gear reduction ratio?
    That 4th blade have been more drag than help.
    Where did the 3900 rpm figure come from, My notes say 3800 rpm.
    ,rc
  5. flboater
    flboater New Member
    Miami Florida
    I was told by the Yanmar person that I need to have a range between 3800 and 4000 rpm. I figure that 3900 is the ideal target. I would be happy though with good performance and 3800 since I tend to cruise at 3400-3500 and never go to 3600.
    I have the same gear as on the gas boat. Also, the boat is a semi-pocket drive. With the currentprops (20x18) i have only about an inch or so clearance. One thing I notice with the current props is that the boat jumps up to the 14-15 knots fast. Based on this, I hope that the next round of consulation results in a recomendation to decrease diameter and increase pitch.
    Still, I would like to know what speed the boat should really cruise at.
    Original performance specs could be found in some magazine boat test (way back issues). C C web site. C C forums (good ones here at YF).
    There is a science (black magic) to pocket or tunnel drive wheel selection. Every time I think I understand some of it , I'm usually wrong.
    Let us know what you find,
    rc
