Click for Ferretti
Click for Horizon
Click for Bertram
Click for Lurssen
Click for McConaghy
Click for Burger
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Yacht Escort & Transport Ships > Yacht Transport Ships & Dockwise > Sunseeker Apache Transport in Europe
Reply
Old 06-25-2012, 06:52 AM   #1 (permalink)
Registered User
Hi, Am looking for someone that can transport my 1995 Sunseeker Apache from South of France to Malta.
tomahawk is offline   Reply With Quote
Old 06-26-2012, 04:14 AM   #2 (permalink)
Senior Member
K1W1's Avatar
If you pick your weather and routing why can't you run it on its own bottom?
K1W1 is offline   Reply With Quote
Old 06-26-2012, 06:47 AM   #3 (permalink)
Registered User
Quote:
The Apache is powered by 2 Volvo KAD 42 engines (2x230hp diesel) with Z Drives. I was told by many that these drives and engines will not "enjoy" such a long trip !
Old 06-27-2012, 01:19 AM   #4 (permalink)
Senior Member
Quote:
Why not????
Capt J is offline   Reply With Quote
Old 06-27-2012, 06:43 AM   #5 (permalink)
Senior Member
K1W1's Avatar
The boat should be able to make it under it's own power if the engines and drives are in good nick and you do not operate it at WOT all the way.
It also looks to be a bit under powered compared to others I have seen on line.
If you head east towards Genoa and then work your way down the Italian coast stopping for fuel and the night when required you could get down to bottom of Sicily and then shoot across to Malta when the weather is good. It is longer that way than going for the Bonifacio Straits but you are never far from a port of refuge should things go pear shaped.
I spent a summer in a Superhawk 52 with triple 315 hp Yanmars. I worked out we had a max range of 300 nm in fine weather. This was sorely tested a couple of times in heavy weather when doing Toulon to Mahon which is 215 nm from memory. We never ran out of fuel but it is better to be safe than sorry. That same boat has been to Greece and back on it's own bottom from Monaco so it is possible in a small boat if planned well.
I found a review of a 45 Apache with 600 hp Seateks with 1400 lts fuel , they give a range at 25 kts of 335 nm. Not sure how this stacks up to yours but if you run along the coast for the first tankful you should get an idea how far you can go in similar weather.
I have found when doing long runs at high speed in small boats it is much easier and safer to do it during the day if possible. If you get up and start to get going just pre dawn and make plans to be in somewhere tied up refueled and ready to go before dark your journey will seem a lot more enjoyable than straining to see a light reflecting on the surface that seems to be miles away one minute and just ahead the next as you blast towards it at 30 or 40 kts on a moonless night then trying to arrive in an unknown location in the middle of the night.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 06:00 PM.
Click for Christensen
Click for GPlink
Click for Dockwise
Click for Trinity
Click for Walker
Click for Nordhavn
