Click for ISA
Click for Dyna
Click for Westport
Click for Lazzara
Click for Benetti
Click for Queenship
Go Back   YachtForums.Com > YACHT DESIGNERS > Yacht Renderings & Plans > Lars Modin Design III
Closed Thread
Old 02-09-2007, 05:19 PM   #61
AMG
YF Moderator
AMG's Avatar
Yes, there are more rules and regulations than one can believe...
We are having our production boats certified for CE class B and with DNV (Det Norske Veritas) classification. One pretty stupid CE rule is that all electric wires must have the same color and a marking in both ends. We used to have wires in 18 color combinations which you could follow all the way, now you just see a bunch of black wires clamped together...
Here is our new 40-footer during sea trials at 47 knots, which is almost 10 knots above the competition, or 25% better mileage!
__________________
Designing the future classics, today.
www.modin-design.com
AMG is online now
Old 02-09-2007, 06:09 PM   #62
Codger
YF Wisdom Dept.
Looks like a nice way to get around. Still using the Volvos?
The wire codes are .. I can't think of an adjective that wouldn't be censored.
Did you label them individually or run separate cable production runs using different identifier printwheels so that any individual wire could be identified at any point to avoid the risk of a field tech/user sticking a darn probe in to every wire until he finds the right one? I lose sleep over the thought of someone sticking a probe in to a cable and 2 or 3 years later having that wire fail because the insulation was breached and the conductors corroded.
Codger is offline
Old 02-09-2007, 06:52 PM   #63
AMG
YF Moderator
AMG's Avatar
In our first boats we have installed twin Volvo D6 350/DP:s, they are very nice engines, but some clients want even more speed so there may be twin Yanmar 480:s with Arneson installed later on. But in general I think we should remain under 50 knots in this kind of family commuter. We now have a cruising speed of 40 knots at under 3 l/Nm, I think it was 2,3 l at 36 knots.
About the wiring, we used to have marks in both ends and a separate colour for each wire. Now we are forced to have neutral black (or red) cables all the way with just the marks at the ends. Thats EC...
__________________
AMG is online now
Old 02-09-2007, 07:23 PM   #64
Codger
YF Wisdom Dept.
Do you have a photo of the engine installation that you could post?
2.3 litres per NM. Is that the total fuel flow or per powerplant? Not trying to be cheeky but half an imperial gallon per NM at 36 knots in a 40 footer total fuel consumption is a number I just have to ask about to make sure that I have not misunderstood.
Codger is offline
Old 02-09-2007, 07:36 PM   #65
AMG
YF Moderator
AMG's Avatar
I don´t have the test results here, but we had Volvo technicians at the seatrials and these are about the figures I remember and for both engines together. We have very good results on all our models, the 25-footer takes 0,77 l/Nm at 36 knots, the 32-footer 1,2 l at 36 knots.
Here is the engine installation in the 40-footer.
__________________
AMG is online now
Old 02-09-2007, 07:49 PM   #66
Codger
YF Wisdom Dept.
Thank you. Looks good. Could pull an engine and slap in a replacement without too much muss and fuss.
Congrats on the fuel consumption efficiencies. Quite an accomplishment. If there were a smilie for applause I'd use it right now.
I wonder about some of the people that come up with the regs. Imagine the havok that is created when someone goes using a probe trying to identify a wire when one of the ones that he doesn't need but pierces anyway is coming from a high gain sat com dish. Fairly high output Rf bleeding in to adjoining low voltage control wiring can ruin your whole day.
Codger is offline
Old 02-09-2007, 07:50 PM   #67
AMG
YF Moderator
AMG's Avatar
Thanks for the congrats! On this picture you can see on top of the screen, that I am cruising at 40,2 knots GPS speed and both engines are showing 3.000 rpm, top revs are 3.600 on these machines.
__________________
AMG is online now
Old 02-10-2007, 06:03 AM   #68
AMG
YF Moderator
AMG's Avatar
Here are some additional pictures from this boat, the interior is made of teak with floors in bamboo. The entire boat is with light-weight sandwich materials and composite construction, vinylester and some carbon fibre. Displacement is just 6.7 tonnes with all added equipment but without fuel or water. All equipment and materials are top quality, like Mastervolt, Corian, Sunbrella, Vola and we even have spring matrasses in both cabins! Hope you like this clean design....
__________________
AMG is online now
Old 02-10-2007, 06:05 AM   #69
AMG
YF Moderator
AMG's Avatar
Moving forward...
__________________
AMG is online now
Old 02-10-2007, 12:28 PM   #70
Codger
YF Wisdom Dept.
There are a lot of little things that are done right on that boat. It's usually little things like round door knobs instead of levers and sharp corners at a child's head height that make me cringe and want to leave a boat as quickly as possible with the feeling that if I can see little things done thoughtlessly then what nasty bits are there that I can't see.
Best wishes AMG, and hope that the market receives these well.
Codger is offline
Old 02-10-2007, 01:05 PM   #71
Arniev
Senior Member
Arniev's Avatar
Hi, Lars.
Congrats on the sea trials!
The interior's clean, functional design is simply beautiful.
Arnie
Arniev is online now
Old 02-10-2007, 03:00 PM   #72
AMG
YF Moderator
AMG's Avatar
Thanks both of you, and Codger, the small details are my specialty...
Here are a couple of them. Under the seats each side of the aft cockpit are the fuel caps. Below is an overfill protection device from Vetus and on top of this is a tray if you should get some dripping, which otherwise often result in stains on the teak decks or slippery side decks...
Another feature is my special bollard design that works even better in reality than I was hoping for. Looks quite fun too...
__________________
AMG is online now
Old 02-10-2007, 03:05 PM   #73
nilo
Senior Member
Quote:
Originally Posted by AMG
Moving forward...
Lars well done, very impressive. Could you also post some photoes from the aft deck?
nilo is offline
Old 02-10-2007, 03:22 PM   #74
Codger
YF Wisdom Dept.
Neat! Anything that can be done to keep the fueling process clean is a plus.
Does the overfill protection device from Vetus work on foam or just liquid. I've dealt with some fuels that just seemed to foam like crazy.
The bollard is interesting in another way. Running the line through the gap and then up and around to make it fast might keep it from squinching. Looks like a good plating job as well.
Codger is offline
Old 02-10-2007, 03:24 PM   #75
AMG
YF Moderator
AMG's Avatar
Thanks Nilo,
I have no good pictures of the aft deck, you see a glimpse of it above, but I will repost the drawings where you can get a good understanding of the boat.
She is 12,5 m long including swim platform and 3,65 m wide.
__________________
AMG is online now
Closed Thread
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 12:48 PM.
Click for Christensen
Click for Moonen
Click for Rybovich
Click for NVTI
Click for Shadow
