Click for Nordhavn Click for Glendinning Click for Burger Privacy Matters Click for YF Listing Service
New Shorepower Cable w/ Indicator
Discussion in 'Yacht News; Builds & Launches' started by YachtForums, Oct 11, 2005.
  1. NEW SHOREPOWER CABLE INDICATES WHEN POWER IS ON...
    Nothing is more frustrating for a cruising boater than to plug in at the dock and have no power. To help pinpoint the source of the problem, Hubbell's new 30-amp shore cable set contains a green, LED "Power-On" indicator at the end, which illuminates when power is present through the end of the cable.
    Unlike LEDs on other products, the bright, green LED on Hubbell's cable is easily visible, even in bright sunlight. Thanks to the cable's fully molded design, the indicator and internal electrical connections are completely waterproof and durable. The connector end has a non-metallic, threaded sealing ring, which makes the inlet/connector interface watertight. The ends are ergonomically styled for easy handling and connection/disconnection.
    Hubbell pre-wires the cables at the factory with #10 AWG wire, using copper-crimp barrel terminations for a tight connection and long life. The cables are UL-listed for the U.S. market and CUL-listed for Canada.
    The new Hubbell 30-amp cable sets with LED "Power-On" indicator are available in lengths of 25', 35' and 50', and come in yellow or white. Retail price of a 30' cable set is $98.75.
    Contact Hubbell Marine Electrical Products, 185 Plains Rd., Milford, CT 06460. Phone: 203-882-4800; Fax: 800-255-1031; www.hubbell-marine.com
