Click for Nordhavn Click for Ocean Alexander Click for Glendinning Click for Delta Click for Cross
New Launch: Vicem Yachts 32M RPH "Bronko I"
Discussion in 'Yacht News; Builds & Launches' started by Yacht News, Nov 13, 2012.
  1. Vicem launches 32-meter RPH yacht "Bronko I"
    The latest yacht by Vicem has launched in Turkey. She is the 32-meter RPH design called "Bronko I". The 32M Raised Pilothouse "Vulcan" is a 5-stateroom epoxy/corecell Frank Mulder designed MotorYacht. Mulder has designed a totally unique yacht with easy access to the foredeck from the boat deck on the port side with the main deck on the starboard side, creating a full beam, on-deck master stateroom. In addition to 5 guest staterooms, the yacht has 2 crew cabins with ensuite heads which has access from the galley. The main tender is on the flybridge deck, and there are 2 wave runners in a transom garage.
  2. Bronko I is actually 33.56-meters with a 7.8-meters and a draft of just 2.05-meters. Her performance is given directly by her 2 X CAT C32 ACERT marine engines and they power her to a top speed of 23-knots. Cruising speed is just shy of 19-knots and range at top speed is 540-nautical miles -you may not want to sail her that quickly-. However, if operated at cruising speed the range increases exponentially to 810-nautical miles. The interior of Bronko I has been thoughtfully planned and styled by Wetzels Brown & Partners.
    Vicem Yachts - USA
    Dave Mallach
    1535 S.E. 17th Street, Suite B109
    Ft. Lauderdale, FL 33316
    Vicem Yacht - The Yacht for Yachtsmen - Home
