Click for Lurssen
Click for Horizon
Click for Dyna
Click for Quantum
Click for Lurssen
Go Back   YachtForums.Com > YACHT DESIGNERS > Yacht Designers Discussion > Reverse Bows
Reply
Reverse Bows
Old 02-04-2007, 04:21 AM   #1
orion
Senior Member
orion's Avatar
Question Reverse Bows
Reverse bows, is it a new trend in yacht design?
Like this Gatsby styled laid back cruiser...
Opinions?
orion is offline   Reply With Quote
Old 02-04-2007, 10:07 AM   #2
Eric Sponberg
Registered User
Eric Sponberg's Avatar
Personally, I think the stylists are overtaking design to the detriment of good naval architecture. Hydrodynamically, the reverse bow does not make any sense at all. The shape and volume of the hull goes against sound seaworthiness in a seaway--as such a boat powers through waves there is little reserve buoyancy to keep the bow high in relation to the waves and deflect spray. The boat will tend to sumberge in seas, making for a very wet ride indeed. That's fine if that is what you are looking for, and if you are willing to make that sort of compromise towards style.
Eric
__________________
Eric W. Sponberg
Naval Architect
St. Augustine, FL
Eric Sponberg is offline   Reply With Quote
Old 02-04-2007, 11:36 AM   #3
KCook
Senior Member
KCook's Avatar
Could this model be a Med special? Not really intended for big swell?
Eric's points on buoyancy are right on the money, of course. But to some degree couldn't this concern be applied to all of the "wave piercer" family?
Kelly Cook
KCook is offline   Reply With Quote
Old 02-04-2007, 11:47 AM   #4
AMG
YF Moderator
AMG's Avatar
Quote:
Never been to the Med Kelly?
__________________
Designing the future classics, today.
Lars Modin Design
Old 02-04-2007, 05:06 PM   #5
KCook
Senior Member
KCook's Avatar
Ooof! Got me Lars. Only wish I had been to the Med. So is typical Med swell is the same as the Atlantic?
Kelly
Old 02-04-2007, 05:30 PM   #6
AMG
YF Moderator
AMG's Avatar
A little less, but 8-9 meter waves are common in storms and up to 25 m (80 feet) has been measured. I think a large cruise ship was hit by such a wave a couple of years ago and lost all controls when the bridge windows broke...
This was between Corsica and Mallorca, where the Mistral winds can be pretty naughty.
__________________
Lars Modin Design
Old 02-04-2007, 09:31 PM   #7
KCook
Senior Member
KCook's Avatar
Yikes !
Old 02-19-2007, 03:39 PM   #8
Whiteho2
Registered User
This was my Coventry University Final Project. Indeed the initial idea for the reverse bow was a styling element but this 50m yacht was designed to be fast so her bow would raise at speed. The previous thread was correct however in saying that youd be drowned if standing on the forward deck area when in motion.
Whiteho2 is offline   Reply With Quote
Old 02-20-2007, 03:35 AM   #9
Innomare
Senior Member
Innomare's Avatar
Quote:
Eric
Eric, I agree with you on the wavepiercer bow.
However, volume above the waterline does not necessarily equal seakindliness. I recently made a short trip on an Axe-bow ship and saw video footage of tank testing comparing a conventionally bowed ship, an axe bow and a wavepiercer in heavy seas.
The wavepiercer acted as you say, but the axe-bow behaved a lot better at high speeds in heavy seas (and was still going fine when the others were basically sinking). It had a dry ride while it has little or no reserve buoyancy in the bow.
But, there's a lot more to the axe-bow concept than a vertical stemline and high freeboard at the bow. Including some compromises most yacht-owners would not like to make.
Best regards,
Bruno
__________________
Naval Architect - Owner's Representative - Marine Surveyor
Innomare is offline   Reply With Quote
Old 05-19-2007, 04:15 AM   #10
orion
Senior Member
orion's Avatar
Which boat would you be in?
I think the reverse bowed boat have softest and also driest ride.
It also goes at 13 knots vs the traditional flare bow boat goes 8 knots
http://www.youtube.com/watch?v=2aX5Arv-5vw
Old 10-21-2007, 01:10 PM   #11
MikeUSCG
Registered User
MikeUSCG's Avatar
Reverse Bow
In my opinion, the style of a reverse bow is worth any mild drawbacks in handling. This is what i drew up this afternoon; forgive my art skills, please.
MikeUSCG is offline   Reply With Quote
Old 10-23-2007, 09:12 AM   #12
CODOG
Senior Member
Give me a good old 45 degree (fwd raking) stem anyday. I'd rake it even more if the interior package vs overall length would let me.
Got bored, so I worked out that for a (powered / planing) hull designed to be largest possible just under the 24m Load Line Length rule, I can have a hull around 27 metres long stem to transom if the stem is raked around 45 degrees. If the stem is vertical, the hull cant be longer than 25m from stem to transom. Around 6 feet less deck length, designed under the same rule.
CODOG is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 04:33 PM.
Click for ISA
Click for Christensen
Click for Nautical Structures
Click for Queenship
Click for Burger
Click for Oceanco
