Click for Broward
Click for Rybovich
Click for Benetti
Click for Nautical Structures
Click For Dockwise
Click for Westport
Go Back   YachtForums.Com > YACHT DESIGNERS > Yacht Designers Discussion > FEA, Finite Element Anaylsis
Reply
Old 03-08-2006, 04:48 PM   #1
brian eiland
Senior Member
brian eiland's Avatar
I did a little search on this subject prior to making this new posting and discovered a number of threads addressing the subject. But they all seemed to geared toward a particular analysis of say mast, or sails, or hulls etc.
The one thread that spoke to design software in general, a polling;
http://www.boatdesign.net/forums/sho...&highlight=FEA
had been closed for further submissions, so I decided to start this new thread dealing with FEA in particular, and in general.
New Software Approach Hints at FEA Breakthrough;
Promises More Efficient Overall Design Process
by Emil Venere
Mechanical engineers at Purdue University have developed software that promises to increase the efficiency of creating parts for everything from cars to computer hardware by making it possible to quickly evaluate and optimize complex designs.
The new approach integrates the design and analysis processes, which are now carried out separately. Currently, the geometry of a part is first created using computer-aided design (CAD) software. This geometry is then converted into a mesh of simple shapes, such as triangles or rectangles, which, when analyzed using a computer, indicates the part's strength and other characteristics. The painstaking procedure, called finite element analysis, is extensively used in industry.
"It's like taking a continuous curve and breaking it into pieces," says Ganesh Subbarayan, a professor of mechanical engineering at Purdue. "Otherwise, the form is too complex to analyze."
After the finite element model of the part is created, the part is analyzed to see how well it will perform. If a portion of the shape is found to need redesigning, the part's entire mesh must be recreated to reflect the change.
"After the designer designs the object, it is thrown over to the analyst, and the analyst says, 'OK, I think, based on my analysis, that your design has to be modified this way,' and then throws it back to the designer, who makes the modification," Subbarayan says. "That is not very integrated and not very efficient, and that's the reason these problems take so much time and computational power to solve.
"We are trying to speed up this process to make it more efficient by rethinking the way analysis is carried out. Instead of waiting until the end of the CAD process to do the analysis, we are trying to unify both the CAD design and analysis so that they are carried out concurrently."
Information about the software tool is detailed in a research paper recently published online and will appear in the May issue of the journal Advances in Engineering Software. The paper was written by doctoral student Xuefeng Zhang and Subbarayan. The software tool is based on theoretical work by another doctoral student, Devendra Natekar. Natekar graduated in 2002 and now works for Intel Corp., and Zhang graduated in 2004 and now works at General Electric's Global Research Center.
The method could be especially important when dealing with the corporate sensitivities of global competition.
"The overall philosophy behind the design approach can be extended to enable one to understand the impact of changes in suppliers' components on the performance of a complex system without revealing details of the components or the system," Subbarayan says. "This will enable suppliers to retain their proprietary design knowledge without revealing each other's intellectual property. Such strategies are critical as products are increasingly designed and produced in a globally distributed manner."
The software application, which was written by Zhang as part of his thesis, contains about 35,000 lines of Java code.
"That is a big and complex code," Subbarayan says. "If you take problems like finding the optimal shape for common automotive and aircraft structures, you have to somehow find the shape that has the least weight but at the same time won't break. We call that process shape optimization or topology optimization. These shapes have holes in them for bolting them in place or to reduce their weight. You have to decide whether to have one hole or two holes or 10 holes in a part, exactly where to put those holes and how to shape the holes."
Finite element modeling is the de facto analysis tool for numerous industries, Subbarayan says.
"When you use finite elements, you convert the complex differential equations that describe the physics of the part's behavior into simpler algebraic equations that the computer can solve," he says. "It's a powerful method because it enables you to take any complex problem and solve it.
"To describe the geometry, you take this complex object and break it into primitive objects like cubes, spheres, or cones. With our approach, if I only modify some portion of the part, I only modify the primitives directly associated with that portion I am changing and not all of the primitives. If I only change the shape of a specific hole in the part, for example, the rest of the primitive objects are the same shape, so why should I need to reconstruct the whole geometry and remesh the whole geometry?"
Subbarayan calls the approach a "hierarchical, constructive, meshless procedure" because it enables engineers to analyze the changing design of a part without recreating the complex mesh of elements.
"The way it is now, the same CAD software used to make the shape of the part can't be used to analyze the mesh," Subbarayan says. "But now, the same CAD software or some similar CAD-friendly software will be able to do the analysis, and in a much more efficient manner because there is no remeshing."
Subbarayan began working on the project in 1998.
Purdue researchers are using the software tool to design new materials at the microscopic level, and the method also promises to help engineers create optimized shapes of droplets of solder to ensure longer-lasting circuit boards. A similar application is creating optimized arrangement of particles in "thermal interface materials" as they are inserted into microprocessors for heat dissipation. The material is sandwiched between silicon chips and metal heat sinks to serve as a buffer between the two surfaces so that the expanding and contracting metal does not cause the brittle silicon to crack.
"These are all problems in which a shape needs to be modified," Subbarayan says. "In the case of solder, you are talking about what shape a droplet should take — the boundaries of the droplet are constantly modified until the optimal shape is found."
Source: Ganesh Subbarayan, Purdue News Service
Purdue University
_______________________________________
ABSTRACT
JNURBS: An Object-Oriented, Symbolic Framework for Integrated, Meshless Analysis and Optimal Design
Xuefeng Zhang and Ganesh Subbarayan
In this paper, we propose a design-analysis integrated CAD framework termed jNURBS. jNURBS, developed using the Java language, is an extensible, object-oriented framework that enables meshless analysis of physical behavior and optimal design. The geometry as well as the analysis fields (displacement, temperature etc.) are described mathematically using a common representation, namely the non-uniform rational B-spline (NURBS). Thus, NURBS serves to design the geometry as well as carry out meshless analysis, thereby, integrating the design and analysis in an efficient manner. The program kernel provides tools to symbolically describe complex multiphysics problems, methods to manipulate the NURBS entities, a set of primitive NURBS entities, and an iterative optimization solver. The problems are symbolically defined using a newly developed high-level, natural language description through an interface termed JNS (jNURBS Script). A number of example problems, selected from meshless structural analysis, material microstructure simulation, shape optimal design, and equilibrium shape of droplets, are presented to demonstrate the effectiveness and versatility of the framework
brian eiland is offline   Reply With Quote
Old 03-08-2006, 10:46 PM   #2
KCook
Senior Member
KCook's Avatar
Sorry to be a Luddite, but an analytical application written in Java is hard for me to take seriously. That it is somebody's college project makes perfect sense.
Kelly Cook
(C and Fortran survior)
KCook is offline   Reply With Quote
Old 03-11-2006, 12:26 AM   #3
Codger
YF Wisdom Dept.
There are some people at Boeing, GM, Ford, General Dynamics to name a few, whose eyebrows would be raised if they read this as they looked at their workstations while trying to believe that they were hallucinating what it was that they were looking at.
Codger is offline   Reply With Quote
Old 01-16-2008, 09:32 AM   #4
balboa
Posts: n/a
FE software
Germanischer Lloyd (www.gl-group.com) has a software for FE analysis called Poseidon.
If they push it, I'm sure it will do the job,
Thorwald
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 04:17 PM.
Click for Trinity
Click for Oceanco
Click for ISA
Click for Trinity
Click for Burger
Click for Lurssen
