| |  | Reverse Bows |  | |
02-04-2007, 04:21 AM
#1 | | Senior Member
| Reverse Bows
Reverse bows, is it a new trend in yacht design?
Like this Gatsby styled laid back cruiser...
Opinions?
02-04-2007, 10:07 AM
#2 | | Registered User
Personally, I think the stylists are overtaking design to the detriment of good naval architecture. Hydrodynamically, the reverse bow does not make any sense at all. The shape and volume of the hull goes against sound seaworthiness in a seaway--as such a boat powers through waves there is little reserve buoyancy to keep the bow high in relation to the waves and deflect spray. The boat will tend to sumberge in seas, making for a very wet ride indeed. That's fine if that is what you are looking for, and if you are willing to make that sort of compromise towards style.
Eric
__________________
Eric W. Sponberg
Naval Architect
St. Augustine, FL
02-04-2007, 11:36 AM
#3 | | Senior Member
Could this model be a Med special? Not really intended for big swell?
Eric's points on buoyancy are right on the money, of course. But to some degree couldn't this concern be applied to all of the "wave piercer" family?
Kelly Cook
02-04-2007, 11:47 AM
#4 | | YF Moderator
| Quote: | Originally Posted by KCook Could this model be a Med special? Not really intended for big swell?
Never been to the Med Kelly? |
02-04-2007, 05:06 PM
#5 | | Senior Member
Ooof! Got me Lars. Only wish I had been to the Med. So is typical Med swell is the same as the Atlantic?
Kelly
02-04-2007, 05:30 PM
#6 | | YF Moderator
A little less, but 8-9 meter waves are common in storms and up to 25 m (80 feet) has been measured. I think a large cruise ship was hit by such a wave a couple of years ago and lost all controls when the bridge windows broke...
This was between Corsica and Mallorca, where the Mistral winds can be pretty naughty.
02-04-2007, 09:31 PM
#7 | | Senior Member
Yikes ! |
02-19-2007, 03:39 PM
#8 | | Registered User
This was my Coventry University Final Project. Indeed the initial idea for the reverse bow was a styling element but this 50m yacht was designed to be fast so her bow would raise at speed. The previous thread was correct however in saying that youd be drowned if standing on the forward deck area when in motion.
02-20-2007, 03:35 AM
#9 | | Senior Member
| Quote: | Originally Posted by Eric Sponberg Personally, I think the stylists are overtaking design to the detriment of good naval architecture. Hydrodynamically, the reverse bow does not make any sense at all. The shape and volume of the hull goes against sound seaworthiness in a seaway--as such a boat powers through waves there is little reserve buoyancy to keep the bow high in relation to the waves and deflect spray. The boat will tend to sumberge in seas, making for a very wet ride indeed. That's fine if that is what you are looking for, and if you are willing to make that sort of compromise towards style.
Eric |
Eric, I agree with you on the wavepiercer bow.
However, volume above the waterline does not necessarily equal seakindliness. I recently made a short trip on an Axe-bow ship and saw video footage of tank testing comparing a conventionally bowed ship, an axe bow and a wavepiercer in heavy seas.
The wavepiercer acted as you say, but the axe-bow behaved a lot better at high speeds in heavy seas (and was still going fine when the others were basically sinking). It had a dry ride while it has little or no reserve buoyancy in the bow.
But, there's a lot more to the axe-bow concept than a vertical stemline and high freeboard at the bow. Including some compromises most yacht-owners would not like to make.
Best regards,
Bruno
__________________
Naval Architect - Owner's Representative - Marine Surveyor
05-19-2007, 04:15 AM
#10 | | Senior Member
Which boat would you be in?
I think the reverse bowed boat have softest and also driest ride.
It also goes at 13 knots vs the traditional flare bow boat goes 8 knots http://www.youtube.com/watch?v=2aX5Arv-5vw |
10-21-2007, 01:10 PM
#11 | | Registered User
| Reverse Bow
In my opinion, the style of a reverse bow is worth any mild drawbacks in handling. This is what i drew up this afternoon; forgive my art skills, please.
10-23-2007, 09:12 AM
#12 | | Senior Member
Join Date: Jan 2007 Location: Bournemouth, southern England
Give me a good old 45 degree (fwd raking) stem anyday. I'd rake it even more if the interior package vs overall length would let me.
Got bored, so I worked out that for a (powered / planing) hull designed to be largest possible just under the 24m Load Line Length rule, I can have a hull around 27 metres long stem to transom if the stem is raked around 45 degrees. If the stem is vertical, the hull cant be longer than 25m from stem to transom. Around 6 feet less deck length, designed under the same rule.
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 02:31 PM. | |
