Click for Northern Lights Click for YF Listing Service Click for Abeking Click for Westport Click for Ocean Alexander
specifying wood species, grade, and cut for restoration
Discussion in 'Yacht Designers Discussion' started by Tangusso, Jan 1, 2010.
  1. Tangusso
    Tangusso New Member
    NH
    I will begin work on a 1932 Richardson 32' cruiser soon. As part of the planning, I need to know the correct specifications for the following wood:
    White oak for use in the keel / stem
    White oak used for framing (ribs)
    Cypress used for planking
    I want to be sure I order the correct grade / cut for each. Can anyone suggest a resource for this information, and a supplier that routinely deals with boat lumber?
    We are located in NH, USA. Thanks for your help.
  2. SeaEric
    SeaEric YF Historian
    out on the dock
    I would suggest that you contact Jim Moores at Moores Marine in Riviera Beach, Fl. He is an expert on wood and wood boat repairs.
  3. Tangusso
    Tangusso New Member
    NH
    Thank you Eric. I will start there. If anyone is aware of another good source, in the Northeast perhaps, I would greatly appreciate any input.
  4. Henning
    Henning Senior Member
    Ft Lauderdale FL
    You have a great resources available reasonably nearby you as well in both Mystic Seaport Connecticut and Camden Maine.
  5. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Camden Marine and Wayfarer are 2 very good resouces to look in to.
  6. Tangusso
    Tangusso New Member
    NH
    Unfortunately I am not familiar with Camden Maine. Where dio you suggest I start looking there?
  7. BMS
    BMS Senior Member
    Savannah GA
    Im sure the guys at the wooden boat school can help. They offer a lot of different courses that might be helpful to your restoration. Good luck
    www.thewoodenboatschool.com
  8. maldwin
    maldwin Senior Member
    Dark Harbor Me/ Hobe Sound Fl
    I had a good experience restoring a Huckins at Yachting Solutions in Camden. They are currently restoring a Trumpy, and should be able to give good advice.
    Best,
    Maldwin
