Click for Westport Click for Nordhavn Click for Westport Click for Burger Click for YF Listing Service
News: 26M Wally 'WallyAce' motoryacht
Discussion in 'Wally Yacht' started by Yacht News, Oct 20, 2011.
  1. Wally 26-meter 'WallyAce' motoryacht in build
    Italian builder Wally has kicked off it 'megayacht' motor yacht line with the construction of the "WallyAce" model -the design was introduced some time ago- of which a few units on the 26-meter variant are in build. There are two variants so far, the 26-meter (86-feet) and the 36-meter (118-feet).
    The WallyAce 26-meter model is expected to be launched in 2012. This variant is expected to mount twin CAT marine engines, CAT C12s with 350-horse power each allowing her to run to 12-knots. She is not a speedster because economy in cruising is to be a hallmark. For instance, at 10-knots this WallyAce model will travel 2,400 nautical miles.
    Accommodation for the 26-meter variant varies because one of the two that are in-build has a three-stateroom layout and the second hull has a four-stateroom layout. The three-stateroom WallyAce, or the first hull has a master stateroom located aft on the hull. There is large and vast floor-to-ceiling glass on the aft end of the room and the double bed is oriented towards the aft to take in the views through that large expanse of glass, quite a special feature on the first hull.
    The second hull has four staterooms and the master stateroom is located more amidships in the hull. Amidships also on the starboard side of the hull, is a large garage shell door to house the yacht's main tender and toys. The interior seems to be going toward a modern and minimal appeal with the wide use of teak, glass, and polish stainless-steel in the mix of main materials to be used. Look out for these new models in 2012 where their design alone will be enough to turn heads.
    Wally Yachts,
    8 Av. des Ligures
    MC98000 Principality of Monaco
    Wally
