Click for Garcia
Click for Bering
Click for DeAngelo
Click for Oceanco
Click for Lurssen
Click for Garcia
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > SportFish Yachts > Viking Yacht > 85% throttle showing 100% load
Reply
Old 10-23-2011, 05:11 PM   #1 (permalink)
Registered User
Have a 45 Viking Convertible with 900 MANS. The boat has sat for over a month and has signs of growth on it. Originally thought that it was fuel filters and changed them, but still have the same problem. The boat will just get up on plane but is slow. There is no fibration but I feel that this is due to growth. Showing 100% load at 85% throttle and stays at 100% load from 85% to 100% throttle. Any thoughts beyond growth on the bottom and props?
Kahuna45 is offline   Reply With Quote
Old 10-23-2011, 06:47 PM   #2 (permalink)
Senior Member
Bamboo's Avatar
A dirty bottom is the first thing I'd suspect after sitting for a month. Have it cleaned and then check again.
Bamboo is offline   Reply With Quote
Old 10-23-2011, 07:25 PM   #3 (permalink)
Registered User
Thanks.... Diver coming Tuesday
Old 10-23-2011, 08:01 PM   #4 (permalink)
Senior Member
BEAU's Avatar
What are the historic numbers??
BEAU is online now   Reply With Quote
Old 10-23-2011, 08:18 PM   #5 (permalink)
Senior Member
If the bottom is dirty then that definately is the problem. Also make sure fuel filters are clean/new both primary and secondaries. If that's fine then the boat is overpropped.
Capt J is online now   Reply With Quote
Old 10-24-2011, 02:45 PM   #6 (permalink)
Senior Member
NYCAP123's Avatar
This has been a summer for serious growth up here. I took a boat out of Conscience Pt. 2 weeks ago that had been sitting. Wouldn't come on plane, vibrated like a Motel 6 bed. Luckily she only had to fo a few miles to her winter home because I could only make 7.5 kts without shaking her apart. We typically start getting the bad growth during the last 2 weeks of August up here. This year it was more like being in So. Florida. Your diver should have you back in shape, but don't be surprised if he charges you a bit extra. He'll have a lot of scraping to do.
P.S. If the diver does good by you please PM me his info. The guy I usually recommend has retired. Thanks.
NYCAP123 is online now   Reply With Quote
Old 10-24-2011, 08:39 PM   #7 (permalink)
Senior Member
I agree, check for bottom growth.
I came out for Irene and bottom was clean.
Just yesterday I noticed that the bottom was pretty slimed.....
a few barincles or some growth on the shafts and wheels can easily knock off a few hundred RMP off the top.
oh yea, check the racors too....did you mention that in OP?
good luck
RT46
RT46 is offline   Reply With Quote
Old 10-24-2011, 08:40 PM   #8 (permalink)
Senior Member
ok, i went back and read the OP,
yes you did ck the filters....
I bet it is the growth on the bottom
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 10:00 PM.
Click for Alexseal
Click for Westport
Click for Pacific Mariner
Click for McConaghy
Click for Delta
Click for Burger
