Click for Llebroc
Click for McKinna
Click for Alexseal
Click for Delta
Click for Trinity
Click for Walker
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > SportFish Yachts > Viking Yacht > Viking 63 MY questions (1990 built)
Reply
Old 01-13-2011, 09:56 AM   #1 (permalink)
Senior Member
Pascal's Avatar
i'm helping a new owner with a 1990 built, viking 63MY and i have a few questions that are left unanswered by the "light" owners manual...
unfortunately there are no blue prints or serious diagrams (wiring, plumbing, etc...). he's going to check with Viking but in the meantime, knowing how good YF is, i'm sure someone may have the answer!
1)- the boat has a 1000USG primary fuel tank under the master, as well as an optional fuel tank under the forward SR. there is no mention or info on the optional fuel tank. previous owner/broker mentioned 400USG, but i'd like to verify that nr.
2)- according to the manual, the water tank is under the forward SR... this one, because of the of the aux fuel tank has the water tank under the master bed. any idea of the capacity?
3)- same question with the hodling tank, it's not in the ER as per the plan but next to the aux. fuel tank forward... capacity unknown...
4)- any idea where the holding tank vent may be? i've opened every hatch, and panel i can find and no luck.. i want to know if it has a filter.
thks guys!!
Pascal is offline   Reply With Quote
Old 01-13-2011, 10:47 AM   #2 (permalink)
Registered User
captainwjm's Avatar
Viking spec's
Pascal, my 55' '89 MY does not have an auxiliary tank, so can't help you there, but FWIW, my waste tankage is 65 gallons, and water tankage is 300 gals. Holding tank vent is at the waterline, stb. side just forward of the 2 AC discharge ports.
captainwjm is offline   Reply With Quote
Old 03-06-2011, 08:16 PM   #3 (permalink)
Registered User
Greetings Pascal, I captain a 63' as well. The primary tank holds 1080gals,the fresh water is 350gals and about 60gal for the waste. This is the first time I've herd they had an option for an aux fuel tank. Also as captainwjm posted, the vent is in the same position on the 63. Last, your pretty much wasting your time trying to deal with Viking for any info on this model, been there, done that....
dawgmode is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 02:43 AM.
Click for Lurssen
Click for Garcia
Click for Ferretti
Click for Burger
Click for Pacific Mariner
Click for DeAngelo
