Click for Burger Click for Nordhavn Click for Westport Click for Ocean Alexander Click for Northern Lights
Viking 35 Window Replacement
Discussion in 'Viking Yacht' started by ELYSIUM, Jun 1, 2009.
  1. ELYSIUM
    ELYSIUM New Member
    Louisville,KY
    Has anyone replaced their side or front windows with permanent tempered tinted glass? How was it done? Also has anyone ever replaced the vinyl gasket material around the windows of the rear sliding door? Mine have shrunk so bad there are one inch gaps in the corners. Can it be replaced and how?
  2. Bob B
    Bob B New Member
    BayShore LI NY
    replacement windows
    Yes I removed the side windows on my 35' viking I was tired of the leaks and mold growing in the tracks. Beleive it or not the hard part was getting the old windows out and removing the track work. The most difficult part of the job was removing the bedding compound under the window frame. I hired a "Glass guy" to do the install which I watched and found it to be a pretty simple process. The first thing they did was make a templet of the opening and ordered the glass. once the glass was delivered he installed a 1" X 1" aluminim strip around the opening, then they allpied a very strong double stick tape, set the glass and lastley caulked it in place. I have new gotten so many complements on my boat the install up dated the look of the boat and best of all no more leaks. With the glass to glass seam in the middle and no visable window fram on the outside it makes the boat look like a much newer boat then what it actually is 1977.
  3. ELYSIUM
    ELYSIUM New Member
    Louisville,KY
    Window Replacement
    Sounds like the job turned out real well. Do you have any pictures? I would love to see the finished results. Can you send them to: EMAIL ADDRESS REMOVED
  4. YachtForums
    Please read YF's rules before making any further posts Elysium
  5. Bob B
    Bob B New Member
    BayShore LI NY
    see attached pictures
  6. HI-TECH_Charte
    HI-TECH_Charte New Member
    Sheboygan, WI
    The new windows look GREAT !
    I am working on restoring the sliding salon doors on my 1977 35' Viking, but have not been able to find replacment weatherstripping (glazing spline) Has anyone ever done this ? Or am I better off to have new doors made ?
  7. Angelo
    Angelo New Member
    Port Clinton,OH
    Viking sells that felt like stuff that goes into the window track . I purchased some for my 1974 33. The material has a funny name like Schlagel. I believe that the spelling may be off but its close. Hope that helps.
  8. Angelo
    Angelo New Member
    Port Clinton,OH
    Rubber Glazing material
    C L Lawrece Co sells by the roll rubber material that I think will work. Its their number RG38100 Glazing Gasket. You can get it on EBay or on Amazon.com
  9. RT46
    RT46 Senior Member
    nice job on the 35 Viking windows,
    I had the same year 35 and always wanted to do what you did to the salon windows.
    very nice job, great boat
