| |  | Jet Tender Recommendations? |  | |
03-09-2008, 10:17 PM
#1 | | Senior Member
What is the latest in Jet Tenders? I will be looking to get a 4m (+or-) this summer. I had heard that there were some reliability issues with most of the generation 1 models. Any recommendations for and against?
03-09-2008, 11:39 PM
#2 | | Senior Member
My 2c worth- Don't buy one.
Jet Boats have their uses and Tenders for a yacht are not really one of them.
__________________
Cheers,
K1W1
03-10-2008, 12:23 AM
#3 | | Senior Member
Why is that? Is it price? Is it performance? Is it maintenance? Is it space taken up by the motor? Quote: | Originally Posted by K1W1 Hi,
Jet Boats have their uses and Tenders for a yacht are not really one of them. | |
03-10-2008, 12:45 AM
#4 | | Senior Member
I worked on a boat once that had both a jet tender and a RIB novorina. We always ended up using the RIB for the guess as it just seemed so much more functional. It sat more poeple and they were more comfortable in the RIB. The jet tender was nice but just some how never seemed to be needed. Then the maintance did seem to be needed more as well. I remeber the housing around the impellar swelled up with corrision and jammed the impellar..
03-10-2008, 02:19 AM
#5 | | Senior Member
I have been using Jet tenders the last 5 years, the only issue I could mentioned here is that the old two stroke models were smelly and were leaving oil spills in the surface. On our new yacht we have chosen a Williams 4 stroke 104 HP(wember engine) 3.85m. It is a fact that alike jet skis the engine should be washed down with fresh water at least a week ( The crew of our yacht is doing it after each use).
Apart of the above, in my opinion they are much safer to operate especially in crowded beaches and offer a lot of fun
__________________
If U arent thoroughly confused, U arent thoroughly informed
03-10-2008, 07:09 AM
#6 | | Registered User
Castoldi seem to be a popular make at least in the larger ranges - can't say I was overly impressed with the engineering but they do drive well. Ribtech in the uk also make jet tenders using a small Vosper jet unit. They were pretty good as long as you didn't go all electric - having the toggle switch for the bucket control break off in neutral while you're in Nassau shipping channel is not amusing.
03-10-2008, 09:13 AM
#7 | | Senior Member
There are more models appearing every year. I like the safety side of no prop but you do need to flush them daily. I owed a Ribtec Camel 6.5M for 6 years and loved the boat, it wasn't a jet but it rode like an old Cadillac, nice and gentle.
Check out www.ribeye.co.uk and http://www.espritnautics.com/ for Nouveranias
03-10-2008, 12:25 PM
#8 | | Senior Member
| Quote: | Originally Posted by JAG1 Castoldi seem to be a popular make at least in the larger ranges - can't say I was overly impressed with the engineering but they do drive well. Ribtech in the uk also make jet tenders using a small Vosper jet unit. They were pretty good as long as you didn't go all electric - having the toggle switch for the bucket control break off in neutral while you're in Nassau shipping channel is not amusing. |
the main disadvantage of the castoldi is their weight, I was looking to install the smaller model of their range but its dry weight was 900 kg
__________________
03-10-2008, 05:29 PM
#9 | | Senior Member
Can a 4m jet tender, say like the Williams 385, pull a wake boarder with a driver and spotter in the boat?
03-10-2008, 06:27 PM
#10 | | Senior Member
| Quote: | Originally Posted by goplay Can a 4m jet tender, say like the Williams 385, pull a wake boarder with a driver and spotter in the boat? |
Our old tender an AVON DL (Yamaha 85 HP) was pulling a wake boarder but on board was only the driver
__________________
03-11-2008, 02:00 PM
#11 | | Senior Member
Here its pulling a water skier: http://youtube.com/watch?v=0QY8sV6VOJI |
03-14-2008, 03:11 PM
#12 | | Senior Member
Yes, I have a Williams 385 Jet Rib and pulling a wake boarder has been done often.
06-03-2008, 11:07 AM
#13 | | Registered User
| Quote: | Originally Posted by goplay Why is that? Is it price? Is it performance? Is it maintenance? Is it space taken up by the motor? |
They're junk. I have experience with a few of them. The worst was a 14' Nautica RIB jet. It smoked like crazy, was so loud at hull speed you needed ear muffs, and problematic. The 4 stroke outboards have come so far that the jets don't even come close.
The jets use a lot more fuel. Need a lot more maintanence. They are a lot louder inside of the boat because the motor is generally mounted under the console. They don't have the performance of an outboard. You really cannot go in any shallower water then a 4 stroke one. If they have a waverunner motor they vibrate and smoke. Steerage at slow speeds with them is horrible. The best thing about the jet's is if you have to jump overboard fully dressed to clear a plastic bag out of the intake with guests on board. IMO they have no advantages.
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 09:28 AM. | |
