Click for Christensen
Click for Sea Spirit
Click for Lurssen
Click For Dockwise
Click for Crescent
Click for Oceanco
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Tenders & Dinghies > Looking for boat lift or floating dock for dinghy
Reply
Old 05-16-2007, 12:47 PM   #1
Jamie Agnes
Registered User
I have an 11ft Nautica tender with a 40hp 4 stroke engine. I would
like to be able to drive it up onto some type of floating dock to
keep the bottom clean, so that I do not have to pull it completely
out of the water each month. The boat is docked at a slip in a
marina. I have tried the EZ Dock system and that does not work
with this particular boat. Does anyone know about anything else
out there that would work?
Jamie Agnes is offline   Reply With Quote
Old 06-09-2009, 03:22 PM   #2
riptidecrew1939
Registered User
riptidecrew1939's Avatar
HydroPort II
I have a HydroPort II next to my slip and drive my 12' Rendova RIB with a 40hp Honda onto it. It works great. RIB is entirely out of the water and I can launch and recover alone.
Saw the online at Costco about a year ago. Had to call for information when I installed it, but the factory reps were great.
riptidecrew1939 is offline   Reply With Quote
Old 06-09-2009, 08:43 PM   #3
NYCAP123
Senior Member
NYCAP123's Avatar
Put a Jet Dock together several years ago for a bunch od PWC & ribs. Good stuff. Very easy to install and customize. What problem did you have with the E-Z Dock system?
__________________
"Some went down to the sea in ships."
NYCAP123 is offline   Reply With Quote
Old 06-09-2009, 09:12 PM   #4
Capt J
Senior Member
Quote:
The jetdocks work well for a small boat and you can put a ring on the jet dock at the boats midship and run the line through the ring and foward to the eye on boat and winch it off. They're not so wonderful for waverunners as the jet pump is so close to the saltwater that it does a number on the wear rings in the jet pump if you have any wake action with saltwater corrosion.
Capt J is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 07:20 AM.
Click for MCC
Click For Affinity
Click for ISA
Click for Horizon
Click for Moonen
