Click for Mulder Click for Westport Click for Nordhavn Click for JetForums Click for YF Listing Service
Battery charging from prop shaft
Discussion in 'Technical Discussion' started by katieorielly, Aug 19, 2008.
  1. katieorielly
    katieorielly New Member
    Kinsale, Ireland
    Anyone know of a battery charging device which can be engaged onto the rotating prop shaft when under sail?
  2. K1W1
    Yes, A belt driven generator or alternator could be used for this but shaft speed/pulley size is an essential part of any setup.
  3. Castlerock
    Castlerock Senior Member
    New England
    The issue that you need to look at with using the boats prop while the engine is not running is, are you getting proper lubrication to the transmission. Also think about the wear and tear on the transmission while sailing on a long passage. I have had good luck with the tow generators, they make 8 -12 amps of charge under normal conditions. These systems are made for what you want to do and are simple to use. I only have one suggestion, buy a couple of spare props and tow lines. There is nothing worse than loosing your charger to a pod of whales in the middle of the night, in the gulf stream where the phosphorescence illuminates it like a toy.
  4. Skiffy
    Skiffy New Member
    Plymouth
    Towed or shaft
    I'd go with towed, having used one for over 10,000nm in one year, to get a working set up for your shaft its going to cost something. The towed ones really do produce plenty to run all your electrics and you can also use them as a wind Gen when at anchor, or at least you can with the Aquair one I have.
    If your shaft has a water feed to lubricate and cool the stern tube bearing you'll be running it warm and wearing it faster with no water feed from the engine.
