Click for JetForums
Click for McKinna
Click for Cape Scott
Click for Dockwise
Click for Burger
Click for Ferretti
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > water filter systems
Reply
Old 07-29-2008, 11:18 AM   #1 (permalink)
Registered User
I have a Sunseeker Manhattan 50 and would like to know my options on filtering the water either prior to entry into tank or at the various showers and sinks.
Which makes more sense and what suggestions do you have?
Mark G.
markg is offline   Reply With Quote
Old 07-30-2008, 01:24 PM   #2 (permalink)
Senior Member
K1W1's Avatar
It is a lot easier to make up a small filter unit to place in your filling line and to filter your water before it enters the tanks.
You can make something like this http://www.waterfixercompany.com/model1000.html
Don't however be fooled by the blurb on that site. The UV Part of it is no use used the way they have it shown, UV sterilization should be used between the storage tanks and the consumer not before the storage tanks.
If you are going to make your own one or buy one try to get the clear bowls so you can see what the filters look like as you use it- you might get a surprise and not necessarily a pleasant one either!
K1W1 is online now   Reply With Quote
Old 07-31-2008, 10:17 PM   #3 (permalink)
Senior Member
I would highly recommend not filtering the water before putting it into the tanks. You will remove all chlorine from the water and you will have a bacteria and algae farm growing in your water tank in no time.
There are many filters on the market that are easy to install in the out line of your water pump. Look in a few marine catalogs and you will see an assortment and depending on your water line size, I would pick one of those. I have never found the need to put a water filter on a yacht. It sounds as if you have some stuff brewing in your water tank. I would put a 1/2 gallon of bleach in the water fill, top the tank off, let it sit for a few hours and then drain it out of each faucet until the tank is empty and then refill it. You may have to refill and drain 2 or 3 times. But that should eleviate any bleach residue or smells. I normally put a little bleach in with each water tank fill. Maybe an ounce per 100 gallons.
Capt J is offline   Reply With Quote
Old 08-01-2008, 01:27 AM   #4 (permalink)
Senior Member
K1W1's Avatar
You might want to take a look at this article- source is at end of article.
Every day, cases of cancer are rising in astounding and unprecedented numbers.While medical professionals work tirelessly to find a cure for this most deadly of diseases, the numbers of terminally ill patients continue to climb. Although the cure for cancer continues to elude medical professionals, it is completely within our own power to protect our families and ourselves and to reduce our risks whenever possible.
In recent years, individuals have begun to seriously examine known carcinogens and to protect themselves from these cancer-causing agents. Sunscreen has become an important defense against skin cancer, and its use is on the rise. The number of smokers attempting to quit rises each day, precisely because of new information about the carcinogenic nature of cigarettes.
The increase in such protective behaviors clearly indicates an increased interest in protecting oneself from cancer risks. Still, droves of people continue to use and drink unfiltered tap water, not knowing about or not believing in the insidious nature of this substance. Whether we like it or not, the water that emerges from our taps, however pristine it may appear, is filled with carcinogenic compounds. A simple water filter can now serve as a valuable safeguard against cancer.
Chlorine and Tap Water:
Untreated tap water is filled with such dangerous contaminants as nitrate, arsenic,microorganisms, and chemicals from pesticide runoff. Once this water reaches a municipal treatment plant, many contaminants are removed. However, one of the most dangerous contaminants is actually added to drinking water as a part of the treatment process.
Chlorine, added as an inexpensive and effective drinking water disinfectant, is also a known poison to the body. It is certainly no coincidence that chlorine gas was used with deadly effectiveness as a weapon in the First World War. This gas was known to severely burn the lungs and other body tissues when inhaled; it is no less powerful when ingested by mouth. Each day, as we use unfiltered tap water, we are effectively pouring bleach into our water before we drink it.
This poisonous chemical, accompanied by its byproducts, is now known to cause at least three types of cancers, among other serious health problems. The U.S. Council of Environmental Quality recently released a report stating that the risk of cancer is 93% higher among those drinking chlorinated water than among those not drinking chlorinated water! In the following paragraphs, you can read about the specific cancer risks of chlorinated water and learn how to protect your family and yourself from this insidious poison.
Bladder and Rectal Cancer:
Chlorine has long been known to be a leading cause of bladder and rectal cancer.Once in water, chlorine interacts with organic compounds to create trihalomethanes (THMs). These THMs are particularly harmful to the body when ingested. When taken into the body, THMs encourage the production of free radicals. These free radicals proceed to destroy or damage vital cells in the body. Because so much of the water we drink ends up in the bladder and/or rectum, ingestions of THMs in drinking water is particularly damaging to these organs. THMs cause innumerable cases of bladder and rectal cancer each year.
Bladder and rectal cancer occur when malignant cells, often created by THMs, infect the inner tissues of the particular organ. Once they have taken hold in the bladder or rectum, the malignant cells can isolate themselves in the infected area or they can spread to infect other areas of the body, potentially causing more deadly forms of cancer. Each year, 13,000 new cases of bladder cancer are diagnosed in women while 37,000 new cases are diagnosed in men. Of these 50,000 new cases each year, slightly more than 20% of individuals will die from the disease. For rectal cancer, more than 40,000 new cases are diagnosed each year and approximately 55% of those individuals diagnosed will die from the disease.
Ironically, one of the best means of protection against these two types of cancer is drinking plenty of fluids. However, drinking larger amounts of contaminated water only exacerbates the risk.
Breast Cancer:
Breast cancer is the newest type of cancer to be connected to ingestion of
chlorinated water. Breast cancer affects one out of every eight women in the United States alone, and it kills approximately _ of its victims.
Recent research has linked this deadly cancer to a buildup of chlorine compounds in the breast tissue. In a shocking study conducted in Hartford, Connecticut, researchers found that “women with breast cancer have 50% to 60% higher levels of organochlorines (chlorination byproducts) in their breast tissue than women without breast cancer.” While chlorine can make its way into our bodies in several ways, there is no means of access more common or more frequent than the ingestion of common, unfiltered tap water.
A Simple Solution:
One preventive solution to these three deadly cancers could not be simpler. If
chlorinated drinking water is a leading cause of cancer, then the obvious method of reducing one’s risk of cancer is to refrain from drinking chlorinated water. We cannot choose whether or not to drink water, but we can choose the type of water we allow into our bodies.
Municipal water treatment plants add chlorine to water to help make it cleaner and more pure, but once that chlorine has performed its function, there is certainly no reason for it to continue its deadly presence in drinking water. A simple home water filter removes chlorine and its byproducts from drinking water, producing clean, pure drinking water that can also serve as a useful protection against cancer.
Water filters are one of the only methods of water purification capable of removing chlorine.
So, what can a water filter do for you? The answer is simple but extremely valuable.
A water filter can protect an individual from cancer, one of the deadliest killers of the 20th century.
Vanessa Lausch serves as a technical writer for the Aquasana Store, http://www.aquasanastore.com/.
Article Source: http://EzineArticles.com/?expert=Vanessa_Lausch
Old 08-17-2008, 08:00 AM   #5 (permalink)
Registered User
Warning clorox
Warning, If you have a watermaker on board don't put any chlorine (clorox) in your tank especially if you back flush it. It will ruin it! Don't even use the water from the marinas unless you filter it to remove the chlorine. Again this is only if you have a watermaker and back flush it.
CSkipR is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 03:38 PM.
Click for Alexseal
Click for Alexseal
Click for Cheoy Lee
Click for DeAngelo
Click for Oceanco
Click for Christensen
