Click for Ocean Alexander Privacy Matters Click for Burger Click for Ocean Alexander Click for Cross
Prop Shaft packing
Discussion in 'Props, Shafts & Seals' started by finman, May 25, 2004.
  1. finman
    finman New Member
    Oklahoma
    We have a 54' 1996 Bluewater with twin 502 inboards. The port side prop shaft packing is leaking. Is there any way to fix this without having to pull the boat out of the water.
    Thanks,
    Finman
  2. farbo
    farbo New Member
    MI
    packings
    You did not tell whether you have dripless or standard packings. Standard packings need to drip to lubricate the prop shaft (about 2 drips per min.) or so.
  3. finman
    finman New Member
    Oklahoma
    Sorry.
    I believe they are dripless because the other one is not dripping at all. The one that is leaking is a steady stream of water.
  4. brianwill
    brianwill New Member
    Texas
    Have you tried tightening the leaking stuffing box? If you do, make sure you tighten the nuts symmetrically. The box shouldn't drip when the boat's stopped, it should drip a few drips per minute when under way.
  5. brianwill
    Texas
    Finman,
    How are you doing on the stuffing box--did you get it tightened?
  6. finman
    finman New Member
    Oklahoma
    Yes tightening it up helped the leak.
    Thanks for checking back.
    Finman
