Click for Benetti
Click For Dockwise
Click for Shadow
Click for Heesen
Click for Benetti
Click for Quantum
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > To use a thimble ...or not?
Reply
Old 05-21-2004, 02:29 PM   #1
Capt. Joe
Registered User
Capt. Joe's Avatar
Question To use a thimble ...or not?
I am renewing an anchor rode, and have a question.
Has anyone had experience with splicing nylon line [1" three strand] directly to chain without a thimble.
The fit of the thimbles through my hawspipes is rather a tight one and I would prefer to go line to chain on both rodes, but can the connection be trusted???
Would love to hear from crews with experience in this regard, as I've always been a thimble kind a guy, and this guru I asked to do the splicing happens to swear we can go directly to chain... I am skeptical, as the guru is a sailor...
__________________
Capt. Joe
***** IT'S FIVE O'CLOCK SOMEWHERE *****
Capt. Joe is offline   Reply With Quote
Old 05-21-2004, 03:13 PM   #2
John B
Senior Member
John B's Avatar
Wouldn't the rope moving on the chain wear over time?
Isn't that what the thimble prevents?
__________________
John B
2003 Azimut 68 Plus
John B is offline   Reply With Quote
Old 05-21-2004, 04:00 PM   #3
Capt. Joe
Registered User
Capt. Joe's Avatar
Well, no, the line does not move so their is no chafe, or so I am told...
The line is actually braided into the links, much like it would be braided back into itself in the case of a loop around a thimble...
__________________
Capt. Joe
Old 05-22-2004, 07:05 AM   #4
mik-48
Registered User
Tough I didn't trust this method eider. I've been asked to do so on a sailing boat two years ago and to date it works fine.
__________________
capt.Mik
mik-48 is offline   Reply With Quote
Old 06-07-2004, 05:24 AM   #5
GordMay
Registered User
Rope to Chain Splices
There are two basic techniques for fashioning a 3-Strand Rope to Chain Splice: the nearly-conventional “Chain-Eye Splice”, and the “Plaited” splice. See below for instructions.
WEST Marine performed some interesting tests (See link), which determined that the Anchor-Chain-Eye-Splice maintains about 75 - 85% of the rope’s original strength. This was deemed adequate (with explanation).
What the test did not consider, was the effects of shock over time. These were “new” splices, representing an initial condition. They caution that the splice must be examined often.
I’ve found no tests on the “Plaited” style splice, that your rigger seems to be recommending - although I have often heard it "touted" as a better solution. I suspect it's holding power, and would need further assurances as to it's efficacy.
Don't worry about your rigger's being a "sailor", as they generally have much more "anchor time" than power-boaters. He should have experience with similar sized boats and gear, though.
Rope to Chain Splice Test by Chuck Hawley, West Marine June, 1994
http://www.ussailing.org/safety/Stud...hainsplice.htm
3-Strand Rope to Chain Splice Instructions (New England Ropes)(EYE-SPLICE)
http://www.neropes.com/splice/sp72_3...d_to_chain.htm
How to make a Warp to Chain Splice (PLAITED SPLICE)
http://www.bluemoment.com/warpchainsplice.html
HTH
Gord
GordMay is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 10:02 AM.
Click for ISA
Click for Broward
Click for Lazzara
Click for Lurssen
Click for Rybovich
Click for Nautical Structures
