| |  | Hardtop Bimini |  | | |
05-29-2008, 02:45 PM
#16 | | Publisher/Admin
| Quote: | Originally Posted by nbyacht I will build it for you.
Dennis |
Dear Dennis,
Before seizing an opportunity, it is best to do your homework. At YF, that starts with reading our rules on promotion and not posting your email address... on ANY open forum! Your address has been removed.
In the future, you might consider making a proposal on how you would go about accomplishing this, or what experience you have to facilitate the same. To simply jump into a community, offering nothing except a solicitation... is poor forum etiquette.
05-29-2008, 02:49 PM
#17 | | Publisher/Admin
Tarek...
There are several 5-axis mills in Florida, two of them belong to friends that have made a number of molds for me. They also happen to be respected as the best in the biz. You'll need to supply CAD drawings that can be interpreted by their software to produce a foam plug. After that, you can source a someone to make a mold and pull a piece for you. A reasonably adept yard in your vicinity should be able to install it. Be sure to run the drawings by one of Fairline's in-house engineers for structural confirmation.
05-29-2008, 03:03 PM
#18 | | YF Moderator
If this is made from 3D-drawings and milled, you can save about half the cost by milling the mould! It will probably break when removing the hard top, but is good for one. Perhaps you need two pieces, one top and one bottom, if you would like to have less maintenance and nice surrounding shapes for spotlights, loudspeakers and such...
05-29-2008, 03:49 PM
#19 | | Senior Member
| Quote: | Originally Posted by YachtNews Well Tarek, it seems that you have quite a few options now for your envisioned hardtop. Only thing now is for you to choose an option. |
That's true Ron..........what do you think of this hardtop, do you like the idea?
05-29-2008, 03:59 PM
#20 | | Senior Member
| Quote: | Originally Posted by YachtForums Tarek...
There are several 5-axis mills in Florida, two of them belong to friends that have made a number of molds for me. They also happen to be respected as the best in the biz. You'll need to supply CAD drawings that can be interpreted by their software to produce a foam plug. After that, you can source a someone to make a mold and pull a piece for you. A reasonably adept yard in your vicinity should be able to install it. Be sure to run the drawings by one of Fairline's in-house engineers for structural confirmation. | Quote: | Originally Posted by AMG If this is made from 3D-drawings and milled, you can save about half the cost by milling the mould! It will probably break when removing the hard top, but is good for one. Perhaps you need two pieces, one top and one bottom, if you would like to have less maintenance and nice surrounding shapes for spotlights, loudspeakers and such... |
Thank you very much for the suggestions. Are the CAD drawings required of the full boat or the flybridge and radar arch? I would definitely like to install some spot lights and a couple of speakers.
Do they also design the hardtop or how does it work?
Kind regards,
Tarek
05-29-2008, 04:54 PM
#21 | | YF News Associate
| Quote: | Originally Posted by TK-F430 That's true Ron..........what do you think of this hardtop, do you like the idea? |
Yes, it is a great idea for originality and functionability. You just have to be careful with whom you employ to get the job done but trust me, there is a full pool of intelligence and experience here at YF so you will be shown in the right direction.
05-29-2008, 05:19 PM
#22 | | Senior Member
| Quote: | Originally Posted by YachtNews Yes, it is a great idea for originality and functionability. You just have to be careful with whom you employ to get the job done but trust me, there is a full pool of intelligence and experience here at YF so you will be shown in the right direction. |
Excellent and thank you Ron........I am counting on everyone here on YF  . I won't take a step before all of you approve of it.
Kind regards,
Tarek
06-01-2008, 08:42 AM
#23 | | Registered User
Tarek,
The hard top in the image is relatively simple. It doesn't take hi tech milling and all this other stuff. It doesn't take a 500Lb sledge hammer to crack a walnut and after the mould is made by this 3D mill, you still have to fair the mould. This is where most of the labor hours add up. In fairing and finish.
The actual lay-up is really quite simple and doesn't take a whole lot of time.
You will get the same product whether you go with 3D milling or traditional methods the difference is that with traditional tooling you won't be paying for someones milling machine.
Dennis
06-01-2008, 09:38 AM
#24 | | Senior Member
Join Date: Jan 2007 Location: Bournemouth, southern England
Hi Tarek, a couple of considerations for the initial design stage, apologies if I'm stating the obvious....
Presuming you want shade extending as far forward as say, your hands at the helm, and also being supported by your existing mast uprights will make this a very long, thin structure....adding an opening section will obviously take out a vast amount of longitudinal stiffness between fwd and aft ends. You may need to allow for a higher profile and or secondary pillar supports near to half way along the structure.
There are several companies that can make a concertina style opening panel, using standard mechanisms made to individual lengths and widths etc...however, they will all have different sectional dimensions... it will pay you to decide which company you want to supply your opening panel and mechanism before finalising the hard-top design. You will then have a definite set of dimensions to design the track gutters and mechanism mounting around.
Drainage of opening panel track gutters...better sorting this out at design stage, draining the gutters fwd down the fwd support pillars may be best, if you can get a decent drain run, but whatever water you get in the track gutters has to go somewhere.
Racking / sideways movements...difficult one this, you have a fast, lively boat there, crossing wakes / hard turns will have a pronounced affect on the hard-tops sideways inertia...a composite hard-top of this size will weigh in at around a tonne if made with conventional layup so checking the existing mast mounting is up to the increased weight of the hardtop is a must, and careful thought should be given to the mounting of the fwd support pillars, including possibly additional webbing under the mounting point on the superstructure etc.
Access to nav / comm gear, access to bolting points, access to opening section motors etc etc...all better designed in from the get-go.
06-03-2008, 10:49 AM
#25 | | Senior Member
| Quote: | Originally Posted by CODOG Hi Tarek, a couple of considerations for the initial design stage, apologies if I'm stating the obvious....
Access to nav / comm gear, access to bolting points, access to opening section motors etc etc...all better designed in from the get-go. |
Thank you for all the suggestions and for pointing out some very important details which must be considered in the design phase.
Best regards,
Tarek
06-03-2008, 10:54 AM
#26 | | Senior Member
| Quote: | Originally Posted by nbyacht Tarek,
Dennis |
Thank you Dennis for explaining. I have no background or any experience in this field.
Kind regards,
Tarek
11-12-2008, 01:51 AM
#27 | | Registered User
Hello Carl Can you PM me to give me names and numbers for some one to build and install a hardtop on a 106' Westship. I am a Seattle native and can only take so much Florida sun.
Thanks Scott
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 09:00 AM. | |
