Click for Queenship
Click for Platinum
Click for MCC
Click for Westport
Click For Affinity
Click for Cheoy Lee
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Is an Angular Thru hull fitting available?
Reply
Old 05-26-2008, 02:31 AM   #1
katieorielly
Registered User
I need to fit a FLS sonar vertically, but the only location available is not horizontal. Anyone know where can I get an angular thru hull fitting?
katieorielly is offline   Reply With Quote
Old 05-26-2008, 03:30 AM   #2
K1W1
Senior Member
K1W1's Avatar
When you say the only location available is not horizontal do you mean it is in the turn of the bilge?
If so you could extend the opening slightly and make it so the Sonar Unit could sit vertically in the hole even though the surrounding hull section may be far from this.
What is your boat made of?
If it's glass you could get a block built up on the inside to hold it or if it's steel/alu you could get a box welded in to do the same job.
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 05-26-2008, 04:21 AM   #3
katieorielly
Registered User
Angular thru hull fitting
Wow, thank you, that was quick! My Alubat is aluminium and lift keel, my fuel tank is integral just fore of the keel so I can only locate the transducer in front of the tank where the hull rises up at 9 degrees. My other limitations is that she takes to the ground and I cannot sit down on the transducer. Welding a box is major (also within 4" of the tank!). The transducer reeds a standard 2" thru hull bore.
Old 05-26-2008, 04:53 AM   #4
K1W1
Senior Member
K1W1's Avatar
Is your boat Gas or Diesel?
Is this a retractable sonar or fixed?
__________________
Cheers,
K1W1
Old 05-26-2008, 05:09 AM   #5
katieorielly
Registered User
Hi, Its diesel and the sonar is retractable (O rings on the sonar body).
Old 05-26-2008, 05:56 AM   #6
K1W1
Senior Member
K1W1's Avatar
You should be able to get a boat yard to weld in a pipe that you can use to mount the FLS in the space you say you have. No part of this needs to protrude below the hull so you can still ground the boat.
Welding close to a full Diesel tank is a lot safer than welding next to an empty one or a gas tank.
On another note have you ever considered a transom setup for your sonar?
__________________
Cheers,
K1W1
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 06:21 AM.
Click for Horizon
Click For Dockwise
Click for Horizon
Click for Christensen
Click for ISA
