Click for ISA
Click for Nautical Structures
Click for Quantum
Click for Westport
Click for Horizon
Click for Dyna
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > 16v92's
Reply
16v92's
Old 04-13-2008, 12:54 PM   #1
Manny
Registered User
Manny's Avatar
16v92's
Hello everyone,
I'm currently looking into 2 65' Donzis as of now, each with different "versions" of 16v92 engines. one has the standard 16v92TA while the other has 16v92TAB. What does the B in 16v92TAB stand for? are there any significant differences between the two?
thanks
Manny is offline   Reply With Quote
Old 04-13-2008, 02:07 PM   #2
K1W1
Senior Member
K1W1's Avatar
Is this your boat? http://www.castawaynautical.com/z65.html
That came up in a lot of posts when I searched purely for that engine model.
Call your local DDA Dealer and ask what it is all about.
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 04-13-2008, 05:30 PM   #3
Marmot
Senior Member
The B means the engine has a "bypass blower." There is a valve that directs turbocharger discharge air to the airbox above a certain load. It is more complicated due to the bypass control valve but if you are looking max output ... I think there are two versions, 100 percent and around 80 percent bypass, don't know what the difference in performance is.
Marmot is offline   Reply With Quote
Old 05-12-2008, 03:11 PM   #4
Capt J
Registered User
The B model has a turbo bypass and is a beneficial addition to the motor. What the bypass does, it re-routed the turbo boost from the turbo back to the front of the turbo when the throttle's are brought back too quickly (mainly), this saves a lot of wear on the turbo's. It also allows the use of a turbo that may create boost quicker and it will then bypass excess boost, resulting in less intake air charge temperature and less wear and tear on the turbo.
Capt J is offline   Reply With Quote
Old 05-13-2008, 07:06 PM   #5
Manny
Registered User
Manny's Avatar
Thanks again Capt J! Now that you mentioned that, I'm leaning closer to the Donzi with the 16v92TAB.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 05:06 PM.
Click for Oceanco
Click for Shadow
Click for Lazzara
Click for Trinity
Click for Benetti
Click for Queenship
