Click for Walker Click for Abeking Click for Glendinning Click for YF Listing Service Click for JetForums
VeeDrive - loss of hp?
Discussion in 'Technical Discussion' started by golden_fox, Feb 29, 2008.
  1. golden_fox
    golden_fox New Member
    Maldives
    I am looking at doing a Veedrive installation with a pair of 1450 hp engines with a max of 2300 RPM.
    But i have read that there is a loss of hp when compared to a straight drive. Is it true? If so can anyone with experience in Veedrive let me know what kind of loss/reduction in power output can i expect. Such as what kind of speed reduction for the same RPM range can i expect?
    THANKS A LOT in advance!
  2. Garry Hartshorn
    Garry Hartshorn Senior Member
    There are a lot of misconceptions around about v-drives. The short answers is there is no more loss of power than a conventional transmittion of the same gear ratio.
  3. golden_fox
    Maldives
    Thanks Garry. That is most helpful.
  4. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    Most gearboxes reduce the input / crankshaft RPM, via internal gearing, resulting in a lower output / propshaft RPM. There are some minor losses in power between input and output due in part to this gear train. Most modern V-Drives are variants of their equivalent parallel output and down-angle brothers, and share basic case design and much of the same gear train components too....the only real difference is that in a V-Drive configuration the input and output shafts are on the same face of the gearbox casing....the power losses for each configuration are all but identical.
    There is a slight weight penalty to pay for with the V-Drive layout due to two additional shaft flanges, Cardan shaft, additional (usually heavier) mounts and in most cases an engine bell housing.
    Against that, common benefits are...
    The ability to move a large mass further aft (useful if applied to fast planing craft requiring an LCB biased aft)
    The dramatically shortened propulsive machinery installation space required, as the engines are aft of the gearbox instead of fwd of.
    In certain cases, the option of ridgidly connecting the gearbox to the propshaft, without the need of a flexible coupling to take out the inherrent shaft bending tendency of a flexibly mounted engine and close-coupled gearbox.
    In certain cases, the benefit of designing a drive train that can transmit thrust directly to the boats structure, rather than through a flexibly mounted engine and close-coupled gearbox.
  5. golden_fox
    Maldives
    thanks CODOG.....very precise explanation.....certainly very helpful!!
  6. Jorge Lang
    Jorge Lang Senior Member
    Let me know if you need assistance with the exhaust system for your v-drive application.
  7. golden_fox
    Maldives
    Thank you very much!!! Much appreciated!! I am getting my engines down from Florida to the Maldives. So, we can still put items into the container. still have to finalize the engines though.
  8. Innomare
    Innomare Senior Member
    + As said, your speed may be higher, because you can fit bigger and slower-turning propellers (with bigger reduction ratio gearbox) with the same propeller tip clearance.
    + Also your shaft angle may be smaller which helps too.
    - You will have a cardan shaft which needs replacement at certain intervals (check with supplier).
    - If one of the cardanic couplings would ever fail, the spiralling cardan shaft would likely carve a large hole in your engine room bottom.
    - You will need to build a protective cover over the cardan shaft.
    - As mentioned, weight and cost will be higher.
    - The gearbox has to take up the thrust, and this source of noise will be located closer to the accomodation (assuming to be located fwd of the engineroom bulkhead). It's not possible to work with a separate thrustbearing which is a more quiet solution.
    Bruno
  9. golden_fox
    Maldives
    Thanks Bruno!
    That's some very useful points that you have mentioned (the negatives).
