Click for Glendinning Click for Mag Bay Click for YF Listing Service Click for Northern Lights Click for Burger
Detroit Diesel 16v92TA
Discussion in 'Technical Discussion' started by golden_fox, Feb 29, 2008.
  1. golden_fox
    golden_fox New Member
    Maldives
    I am getting a pair of Detroit Diesel 16V-92TA DDEC engines of 1450bhp. Does anyone have any experience with this model of DD? if so i would appreciate any input you can give and comments.
    I would certainly like information on fuel consumption levels - particularly at 1600, 1800 and 2300 RPM (any real hand experience and figures are highly appreciated).
    please feel free to give me the good, the bad, and the ugly!
    THANKS A LOT!
  2. K1W1
    I would not use these engines given any choice.
    They are old hat, the reason you got them is many people are re powering with 4 strokes
  3. Garry Hartshorn
    Garry Hartshorn Senior Member
    I agree totally. At the moment I am running a vessel with these engines, when it comes time to aquire parts you are forced in to using remanufactured parts which seem not to have the quality and have a high failure rate. In their day they were not a bad engine but that day has passed. they are also a dirty engine, tend to leak oil, don't burn clean and are noisy.
  4. Capt. Mike
    Capt. Mike New Member
    Nashville TN,
    If I had all the money in the world I might get 's CAT's or MTU's ,,,, But this is the real world and money matters.
    71 or 92 Detroit are great engines and there nothing wrong with installing them in your boat as long as you keep oil in them you can't hurt them
    Oil leak ,,, yes they have a blow by tube that blows a little oil. I ran a hose to a filter can and it catches all the oil then I pour back into the engine. About a half pint per ten hours of running big deal
    There a lot of 71 or 92 Detroit still in boats and most get rebuilt not changed out. When my 8-71's need rebuilt I will rebuild them not repower.
  5. K1W1
    My background is Engines, these and all forms of High Speed 2 stroke are toast.
    I have worked on many 53's,71's and 92's during my apprenticeship plus a load of other manufacturers product.
    Late 2006 I was called by a really good pal of more than 20 yrs,who was on a boat with 16V-92 Engines he said he needed 6 Cyl Kits for his boat. I asked my contacts in 3 continents and could not find the kits for less then 4 Business Days- best delivery time was in NJ.
  6. golden_fox
    Maldives
    More minuses than pluses....???
    Capt. Mike thanks for your input. its certainly reassuring to know that you have complete trust in them....but i understand that they are not the cleanest but that's manageable.
    K1W1….agreed that it is difficult to get parts as it is certainly old….this particular one was built in 1996
    And Garry has backed it up as well….but your experience with it as having a ‘high failure rate’ is very troubling……it is in complete contrast with what Capt. Mike has stated…..
    Thank you all for bringing in all your experiences and giving me some input. Much appreciated. Will now have to just hold on a bit before making a final decision on whether to buy them or not...hmm....
  7. golden_fox
    Maldives
    Garry....since you have a vessel with these engines, can you give me some figures on the level of fuel consumption at a couple of engine speeds? Say 1600, 1700 and 2300 RPM? Much appreiciated.
  8. golden_fox
    Maldives
    Capt. Mike....I would like to get some information on the fuel consumption of these engines at a couple of RPM ranges....is it possible? Thanks a lot.
  9. Capt. Mike
    Nashville TN,
    you will not have any problem getting parts but if I am not wrong you will have to get parts for two 8-92's. The 16-92 is two 8-92 blocks bolted together with a new 16-92 crank. There are so many they started making the -92 in 1974 it was the last of the 2 stroke and the biggest and the strongest. I wish I had 8-9's but 8-71's are great engines too. mine run great and do very well on fuel you can't ask for more then that.
    http://boatdiesel.com/Forums/index.cfm?cfapp=10&Forum_ID=109
    http://www.thedieselgarage.com/forums/showthread.php?t=62778
    http://www.dieselpartsdirect.com/SearchByCategory.aspx?openid=203
  10. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Jeez....would you buy one? Yes, very cheap to buy but having run both 71 and 92's not my best bet, bit old hat now.
    What would you buy now????
    PS I work with Volvo Penta
    Dave
  11. Capt. Mike
    Nashville TN,
    what size and boat are you putting them in wood, glass, steel or al
  12. golden_fox
    Maldives
    Its a fiberglass hull....with a waterline length of 86 feet.
  13. Fishtigua
    Guernsey/Antigua
    What sort of speed/range are you looking at?
    Fishing or cruising?
  14. Capt. Mike
    Nashville TN,
    It goes with saying Volvo are great engines but so are cat, cummins, MTU it all depends on your budget. if you have the money for new then that is a hard one. If not then 92's might be first on my list but there not bad. you can't kill a old 2 stroke as long as it has oil. I like the cat's but in that HP might be hard to find rebuilt. new all day long.
  15. golden_fox
    Maldives
    Looking at achieving around 17 to 18 knots cruising and a top speed of just over 20 plus.
  16. golden_fox
    Maldives
    Capt. Mike....what's ur take on the fuel consumption?
  17. Capt. Mike
    Nashville TN,
  18. Fishtigua
    Guernsey/Antigua
    Are you doing the boat in Male' or in Mombasa? 92'V8 should do you OK for that sort of range on a dive boat. In Mombasa there used to be a good supply of CAT parts as well. Just a thought.
  19. golden_fox
    Maldives
    Its going to be used in the waters of the Maldives. will be ready for around November....it's also a twin screw. i am becoming more and more unsure about using the 92's
  20. Garry Hartshorn
    The initial design of the 2 stroke detroit diesel was from WW2 they ended up building 4 series the 53 series, the 71 series, the 92 series, and the 149 series. They were intended to be a high power low weight easily maintained engine. They were also intended to be disposable and low cost. In the time when oil was cheap and pollution didn't matter they proved themselves to be a good robust motor. They were also unique in that unlike most engines the majority of parts were inchangable between engines of the same series. For example the the 16V92 uses the same heads, valves, pistons, supercharger, injector pump, injectors, As the 8V92 and many parts from the 4-92 and 6-92. By the way a 16V92 is not two 8V92s bolted together, the block is a single casting.
    I would also like to clarify my comment about high failure rates, I was not meaning the engine but in particular remanufactured parts. I am experiancing a 15% failure rate within 100 hours on remanufactured injectors and turbos and there is no warranty on these parts. The only new parts avaliable are old stock which can be found given time and money.
