Click for Northern Lights Click for Walker Click for Abeking Click for Burger Click for Westport
insulation of Engines exhausts
Discussion in 'Engines' started by comship, Dec 16, 2007.
  1. comship
    comship Senior Member
    Greece
    As I was looking in the market available materials for insulation of the Exhausts of Main Engines I have found the pyrogel 6671 by Aspen Aerogels. It seems to be a really fantastic product based on nanotechnolgy. The Italian vendor assured me that by applying this system, the emitted temperature of the exhausts shall be decreased from 650+ Celcius to 36-37 degrees Celcius.
    Does anyone has any experience of these products?
  2. HONGKONG
    HONGKONG Senior Member
    NASSAU and now Miami
    IN YOUR 3rd SENTENCE, CHANGE EMITTED TO RADIATED. DUE TO THE THERMAL CONTAINMENT PROPERTIES OF THIS PRODUCT, "EMITTED" TEMPERATURES CAN ACTUALLY BE SEEN TO RISE, WHILE INVERSELY, "RADIATED" SHOULD BE LOWERED, BASED ON THICKNESS OR DEPTH OF LAGGING APPLIED. CAREFUL STUDY SHOULD BE APPLIED TO ANY INTERFACES BETWEEN METAL TO GRP/FRP OR METAL TO PAINTED SURFACES AS HIGHER EMITTED TEMPERATURES COULD INDUCE FAILURE OF THESE CONNECTIONS. IN A DRY STACK EXHAUST, STANDOFFS AND SUPPORT BRACKETS MAY NEED (FURTHER) INSULATION AND IN A WET EXHAUST, INJECTED WATER FLOW SHOULD BE MONITORED AND BE DETERMINED TO BE SUFFICIENT BEFORE THE PIPE/GRP, PIPE/HULL INTERFACE.
    AS FAR AS THE CLAIMS MADE BY THE BUILDER, HAVE THEM PUT IN THE SPECS
  3. comship
    Greece
    Thank you for your correction but you did not refer to the specific product
  4. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    Actually, the way I read the product spec, it reduces the surface contact temperature to 36-37 degrees celsius. Pretty important in an engine room, IMHO... less chance of a burn if hman flesh comes in contact with it, less chance of a fire in the case of a petroleum product leak.
    The product looks pretty good to me, but then again I am not an engineer. :cool:
  5. comship
    Greece
  6. comship
    Greece
    Hongkong please do not use capital letters because it seems that you are shouting
  7. HONGKONG
    Not by name (the assumption being you already knew it), but by inference. (see 2nd sentence)
  8. HONGKONG
    I stand rebuked.. Too too many hours in engine rooms, I do this in person also.
  9. comship
    Greece
    You are right the correct term is not emission but radiation
