Click for Oceanco
Click for Quantum
Click for Horizon
Click for Lurssen
Click for Sea Spirit
Click for Heesen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > class A RIVETED aluminium bulkheads
Reply
Old 11-05-2007, 04:27 PM   #1
gattoettore
Registered User
Hello to everybody. I would like to know your opinion relevant to the subject. In our shipyard we build aluminium superstructures. The non load bearing bulkheads were constructed with rivets, i.e. a coaming was welded to decks and to ceilings(transversally and/or longitudinally) and extruded aluminium bulkheads were then riveted to coamings. A class surveyor is questioning regarding the fire test of the bulkhead because of the presence of the riveted connection. Our opinion is that we do not need a fire test, because of we will insulate according to a aluminium A fire rated certificate. Have you ever had an experience like this? What is your opinion?
gattoettore is offline   Reply With Quote
Old 11-07-2007, 06:08 AM   #2
TSI AV
Senior Member
TSI AV's Avatar
Unfortunately, You did not provide info abt yacht's length, Class Society, Al-alloy, etc. ?
But please refer to:
1. As example: GL rules: http://www.gl-group.com/infoServices...sch/inhalt.pdf , You can dig out info there.
2. Check out for information abt Al-constructions/materials on: www.iacs.org.uk
International Association of Class. Societies.
3. Could be great, if You check SOLAS convention, Chapter II-2 as well.
http://www.imo.org/Conventions/conte...257&doc_id=647
Hopefully, this info will be helpful for You.
P.S. Is it a RINA in Your case ?
rgds,
Andrei
TSI AV is offline   Reply With Quote
Old 01-08-2008, 06:03 PM   #3
gattoettore
Registered User
Hello Andrei,
thanks for the information.. I did not connect for a long period... in the meanwhile we had to dismantell the Al riveted bulkheads... classification society: LR
yacht bigger than 3000gt: we are applying SOLAS as passenger vessel.
Thank a lot
Lucia
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 03:39 AM.
Click for Moonen
Click for Dyna
Click For Dockwise
Click for Westport
Click for Oceanco
Click for Queenship
