Click for Lazzara
Click for Christensen
Click for Dyna
Click for Rybovich
Click for Oceanco
Click for Westport
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > fiberglass shaft logs ?
Reply
Old 10-21-2007, 02:21 PM   #1
Kenny's Toy
Registered User
Hi, I have seen a custom boat that is using a full length fiberglass shaft logs around the shafts( Paul Mann ), aparently this makes the boat go faster, some guys have tried it around here and swear they picked around 2 to 2.5 knots.
it not so difficult to do, the problem I have is with the zinc anodes on the shafts, what can I do to ground the shaft without anodes ??
Kenny's Toy is offline   Reply With Quote
Old 10-21-2007, 06:18 PM   #2
Northern Lights
Registered User
cone zincs
There is a zinc that is fitted to a prop nut. Typically the second locknut that retains the propeller is replaced with a special fitting. The fitting acts as a locknut and is also milled to hold a trailing cone zinc. The zinc now trails the prop hub. Very common fitting for race saiboats.
Northern Lights is offline   Reply With Quote
Old 10-22-2007, 05:43 PM   #3
Kenny's Toy
Registered User
Northern, thanks so where can i get some information on this special fitting ?
Old 10-23-2007, 07:58 AM   #4
CODOG
Senior Member
I've not heard of this before. I'd be interested in seeing a photo / link to this.
A 2 knot increase in speed is a bit much to take on trust, my brain tells me the increased diameter of the shaft 'sheath' would if anything add to drag, unless the mechanics of it work because the rotating surface of the shaft is creating more drag originally. Cant see it personally, but would be happy to be proved wrong. Also, I'd be cautious about blocking the water getting into the P / A bracket bearing if indeed one was fitted. Is this 'sheath' around the shaft cylindical or is it shaped, perhaps with an aerofoil section ?
CODOG is offline   Reply With Quote
Old 04-15-2008, 12:14 AM   #5
Spinnaker
Registered User
Why don't you install shaft brush's and bond them?
Spinnaker is offline   Reply With Quote
Old 04-15-2008, 04:27 AM   #6
K1W1
Senior Member
K1W1's Avatar
What is a full length Fiberglass Shaft Log when it's at home?
It sounds like this is another term for the Stern Tube to me but I am happy to be corrected.
BTQ- Zincs are not used for grounding your shaft.
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 04-15-2008, 11:40 AM   #7
Kenny's Toy
Registered User
K1W1 : , shaft tube, stern tube i really don't know how its called
but i have seen it work, I think this idea was picked up from some boatbuilder in Stuart, there have been like 5 boats that have done this modification and all of them picked up some speed, im looking to do this myself next month when my boat is hauled..
Spinnaker : don't know what a shaft brush is , but I will do a search thank you......
Old 04-15-2008, 12:44 PM   #8
Spinnaker
Registered User
Quote:
Shaft brushes work vertually the same as the motor and brushes on an elec. drill. Between the coupler @ the transnision and the shaft log you install a spring loaded lever whereas the spring tension holds the connection against the shaft. This is bonded. http://www.boatelectric.com/shftbrBE.htm These are incredibly easy to fabricate yourself.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 03:57 PM.
Click for Burger
Click for Horizon
Click for Broward
Click for Shadow
Click for Nautical Structures
