Click for Abeking Click for JetForums Click for Ocean Alexander Click for Burger Click for Abeking
Cathodic protection systems
Discussion in 'Technical Discussion' started by balboa, Oct 6, 2007.
  1. balboa
    balboa Guest
    Does anybody have experience with vessels replacing their zinc anode protection with a so-called 'impressed current cathotic protection" system, Like those made by for instance www.cathelco.com?
    And can anybody give feedback on their experience with pipework antifouling/corrosion suppresion systems?
    I'm not talking about something like Barnacle clear that uses sonic vibration which only works on smaller yachts with up to 1/4" plate material.
    And feedback would be greatly appreciated.
    Thorwald
  2. Northern Lights
    Northern Lights New Member
    San Diego
    impressed cathodic control
    Electroguard and Capac Englehard Industries both make impressed systems. Titanium anodes that are serviced at 10-15 year periods are the source of protective current. Electroguard corrosion control systems and electroguard zinc are not the same company.
  3. The Reverend
    The Reverend New Member
    La Paz Mexico
    I have used both Cathelco and Marelco systems in the past on yachts of 60 -75 Meters and the experience has been very good. In one case we retrofitted system as we were having fouling problems on the main sea chest, the results were amazing a pipe that had been regularly choked remained clear.
    These systems do not replace traditional zincs altogether however they are great at keeping clear areas where there is a constant flow (and therefore fouling problems) ie A.C. seawater intakes. Generally they are mounted in pairs one copper and one zinc alloy they are connected to a central control panel in the engine room.
    The anodes are bolted through the hull with a single stud replacing them is a bi-annual drydock job. I have changed one damaged anode whilst in the water using a diver however it´s not to be recommended.
