Click for Nautical Structures
Click for NorthCoast
Click for Christensen
Click for Rybovich
Click for Dyna
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Propeller Clearance
Reply
Propeller Clearance
Old 09-09-2007, 05:36 AM   #1
golden_fox
Registered User
Propeller Clearance
Hi Everyone!
Can anyone give me an indication as to what is a recommended minimum clearance between the propeller blade tip and the bottom of hull? And if the propeller is in a tunnel, does this vary?
Thanks a lot and appreciate any input.
golden_fox is offline   Reply With Quote
Old 09-12-2007, 07:56 AM   #2
CODOG
Senior Member
I would suggest a generalised tip clearance of 1/6th of prop diameter, for both a tunnel and non-tunnel application. Also, I'd use the same ratio of clearance as a minimum from trailing edge of prop blades to leading edge of rudders.
I've seen successful installations with more and less clearance, but the above is a good starting point. Too little clearance is worse than too much usually.
Are you buying a prop / props off the shelf or purpose made ? Is this a tunnel application ?
CODOG is offline   Reply With Quote
Old 09-26-2007, 12:20 PM   #3
Booker
Registered User
15% of prop diameter is a good rule of thumb.
Booker is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 09:00 PM.
Click for Shadow
Click for NVTI
Click for Quantum
Click for Westport
Click for Queenship
Click for Trinity
