Click for Queenship
Click for Moonen
Click for Oceanco
Click for Dyna
Click for Horizon
Click for Crescent
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Should shaft brushes eliminate shaft zincs?
Reply
Old 08-29-2007, 10:40 PM   #1
musky
Registered User
musky's Avatar
My thinking is when a shaft has a brush system that connects it to the main boat zinc plate, there is no need to use shaft zincs.....But I've been wrong before! Does anyone have a definite answer?
musky is offline   Reply With Quote
Old 08-30-2007, 11:16 AM   #2
Northern Lights
Registered User
shaft wipers
In some cases yes in some cases no. You are driving 1/2 a volt @ 1/4 amp. The connection must be clean and maintained. Most low cost brush systems are nothing more than sintered oil-light bearings that have been cut in two and tooled to fit on a tensioned arm. The transmision connection is equally as unreliable. All metals film. What makes stainless steel stainless is that it films a clear coating. Take away the oxegen and stainless crevices. What makes things worse for the connection is the high chromium stainless steels. Aquamet 19 & 22. They like Aquamet in shafting because it doesnt crevice in the rubber bearings. Take away the oxegen and the s/s cant film. The film that forms is chromic oxide. Chromic oxide is dielectric. The oil in the sintered oil-light brush is dielectric. It doesnt take long for the connection to breakdown. Several manufactures produce a silver brush system. The oxide of silver is more conductive than silver itself. The nastier the connection the better. The brushes are silver graphite and the shaft is fitted with a 99.9 % brushing surface.
Northern Lights is offline   Reply With Quote
Old 08-30-2007, 09:47 PM   #3
musky
Registered User
musky's Avatar
Name:  shaft close up.jpg
The brush, or wipe is pretty substantial with heavy gauge wire, but I did hear you loud and clear when you said the connection has to be perfect with such low volt and amps. I'll keep one shaft zinc on per shaft just in case. Thanks for the response!!
Musky
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 05:01 PM.
Click for Quantum
Click for Sea Spirit
Click for Queenship
Click for ISA
Click For Affinity
Click for Lurssen
