Click for Cheoy Lee
Click For Affinity
Click for Lurssen
Click for Oceanco
Click for Horizon
Click for Platinum
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Main Engines on "Classed" vessels
Reply
Old 08-08-2007, 03:33 PM   #1
Hawk
Senior Member
Hawk's Avatar
Has anyone had any experience with using "Type approved only" engines on classed and certified vessels.
At issue is our desire to use MTU 16V2000M93 engines on a ABS classed yacht. These engines are type approved only and are apperently not acceptable for use on a certfied yacht because of their inability to conform to the 10% over load requirement.
Christensen Yachts use the 12V4000M90 which has similar over load issues but are able to achieve certification
Is there anyone who has run into a similar issue- regardless of engine type or manufactor- and has been able to get a variance or exemption?
Hawk is offline   Reply With Quote
Old 08-08-2007, 03:56 PM   #2
Matthias
Registered User
Hi Hawk,
Just to correct you, the last couple of Christensen´s have been M60s, not M90s.
Matthias is offline   Reply With Quote
Old 08-09-2007, 10:32 AM   #3
Loren Schweizer
YF Associate Writer
Is your ABS application putting a finer point on a generalized Maltese Cross A1 Yachting Service AMS ?
Loren Schweizer is offline   Reply With Quote
Old 08-09-2007, 10:52 AM   #4
Hawk
Senior Member
Hawk's Avatar
Loren,
No, nothing out of the ordinary that we are aware of other than we have a relatively inexperienced surveyor that is running "by the book". I have the surveyor investigating the Christensen scenario to see if there is anything different between our application and theirs.
This is our first ABS vessel in over 15 years as we have been working with Bureau Veritas out of France on our previous classed builds. On those vessels there was no issue with the 10% over load factor on the engines as the iron we were using was certifiable.
Jim
Old 08-09-2007, 12:11 PM   #5
MacMcL
Registered User
Get MTU involved, I think you will find that it is not the problem you anticipate.
MacMcL is offline   Reply With Quote
Old 08-10-2007, 08:06 AM   #6
Jorge Lang
Registered User
We are in the final design stage of an exhaust system for a builder using the same MTU engines for an ABS vessel. We have sent drawings of the system to the builder for the surveyor. I would expect other suppliers of components that require ABS approval to do the same including the engine distributor.
__________________
Jorge Lang
Jorge Lang is offline   Reply With Quote
Old 08-10-2007, 09:42 AM   #7
CaptPKilbride
Senior Member
Classifiable Ratings
MTU Engines for yachts
Their online data says all ratings classifiable except for 2000 M93
CaptPKilbride is offline   Reply With Quote
Old 08-10-2007, 12:22 PM   #8
Hawk
Senior Member
Hawk's Avatar
Unfortunately for us the 2000M93 was the engine of choice. We where aware that this engine was not classifable but it was "type approved" and we have been back and forth with both ABS and MTU on this matter to see if we could squeeze it though, but, because this particular engine is wound right out to achieve it's stated horsepower there is no 10% over load factor, therefore unclassifiable as you mentioned.
We have now changed gears and have decided to move forward with the 12V4000, A little more horsepower but a substainial weight penalty, this now requires us to rerun our hydrostatics. In the long run the 12V4000's are a better investment , our next challenge is to mitigate that weight penalty.
Thanks for all your input
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 07:22 PM.
Click for Horizon
Click for Crescent
Click for Heesen
Click for Christensen
Click for FLIR
Click for ISA
