Click for Oceanco
Click for Dyna
Click for Cheoy Lee
Click for MCC
Click for Westport
Click for Heesen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Turbine Question
Reply
Turbine Question
Old 01-13-2008, 07:42 AM   #16
K1W1
Senior Member
K1W1's Avatar
Andrei,
This might shed some light on what No 2 is
http://www.biodiesel.org/pdf_files/f...al_Oct2005.pdf
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 01-13-2008, 08:06 AM   #17
TSI AV
Senior Member
TSI AV's Avatar
K1W1, thanks for a link provided. Are these "Number 1 and Number 2" somehow comparable as Marine Gas Oil (MGO) and Marine Diesel Oil (MDO) ?
Best regards,
Andrei
TSI AV is offline   Reply With Quote
Old 01-13-2008, 12:33 PM   #18
K1W1
Senior Member
K1W1's Avatar
Andrei,
Here is the price of the former-
http://www.bunkerworld.com/markets/prices/ae/fjr/
I will respond with more details when I can either link or c and p some if you need quicker or better you can always data or PM me
I am currently loaded with over 200 tons of some type of diesel fuel which was sold as Automotive Diesel I am in water in a Nthn. Location and it has a wax point of above 8 deg C so I have my own fuel issues. The Lab tests do not resemble anything with this flash point sold in gas stations. I am waiting to see how the various retained samples resemble the spec sheets we were provided with at the time of last bunkering. We loaded some 190 tons then so the problems we now have originate there I would say.
We are currently waiting for tests to see what other nasty surprises we are in for. One that I have managed to bypass is the suggestion we add hydraulic oil to the fuel to re dissolve the wax formation.
Brain Teaser:
Bearing in mind we are looking for the same stuff we run in cars, is there anyone out here on the boards who can tell me what problems we could have other than viscosity control if we added Hydraulic Oil to normal modern automotive diesel.
__________________
Cheers,
K1W1
Old 01-15-2008, 11:00 AM   #19
TSI AV
Senior Member
TSI AV's Avatar
It looks like we've got far away from turbine question...
K1W1, thanks for a link once again. Yes, looks like it's about MDO/MGO.
But they also can be as DMA/DMX and DMB/DMC.
Here is a link about fuel ISO standards:
http://www.owbunker.com/Services/Fuel+specifier?IsoName
And DNV Petroleum Services can be found here:
http://www.dnv.com/maritime/fueltest...NVPS/index.asp
rgds,
Andrei
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 03:57 PM.
Click for Dockwise
Click for Crescent
Click for Quantum
Click For Affinity
Click for Queenship
