Click for Horizon
Click for Westport
Click for Nautical Structures
Click For Dockwise
Click for Sea Spirit
Click for Oceanco
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > What fluid is in a Compass?
Reply
Old 06-10-2007, 05:55 PM   #1
mbursey
Registered User
Does anyone know what kind of fluid Compasses are filled with?
mbursey is offline   Reply With Quote
Old 06-10-2007, 06:11 PM   #2
K1W1
Senior Member
K1W1's Avatar
There seems to be many mediums.
http://www.newton.dep.anl.gov/askasc...1/gen01791.htm
A Compass Adjuster should be able to answer the questions you have about your particular compass.
If you live near the sea and a busy port it shouldn't be to hard to find one of these guys.
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 06-10-2007, 08:47 PM   #3
SeaEric
YF Historian
SeaEric's Avatar
My understanding is that compases are filled with "compass oil". I know it sounds strange, but my Dad ruined a compass years ago by adding alcohol to refill it. The alcohol attacked the plastic sight dome and rendered it unuseable. I'd stick with compass oil if it was me.
http://www.vikingoptics.com/compassoil.html
SeaEric is offline   Reply With Quote
Old 06-28-2009, 04:40 AM   #4
Blair
Registered User
I am showing my ignorance and would appreciate some wisdom from the old hands. I use a smallish fizz boat for fishing fun - not too many miles away from land typically! It is a US built boat and came with some gear. I added a GPS/Plotter together with sounders etc and rarely even look at the magnetic compass to be honest. Given that the compass is a US-fitted model it may perhaps have been balanced for that particular compass zone and obviously not the South Pacific. I know that small handheld dry compasses are balanced according to the various zones they will operate in to stop the needle dipping significantly and catching but are fluid filled compasses similarly vulnerable?? In simple terms, if I had to rely on this compass is it OK here 'downunder' where the Southern bias of the magnetic field is higher?
Blair is offline   Reply With Quote
Old 06-28-2009, 04:55 AM   #5
K1W1
Senior Member
K1W1's Avatar
Quote:
Have you got a deviation card that came with the boat originally?
Have you got a fluxgate compass or heading info on your GPS Display?
If you are fishing the Kaipara it is pretty had to get lost at sea unless somehow you get out over the bar by accident.
If you have a fluxgate or other accurate heading reference just aim your bat along a steady course starting at say 000 until you see where the Maganetic one settles down, ten do this for several other points of the "compass" and work out what the difference is if there is not a set pattern that you can remember then you should make a note of it.
I have yet to see a magnetic compass that is easy to follow in a fizzboat so wish you luck with this.
I have Suunto handheld compass that I brought with me from NZ and have found recently that it seems to work just fine when I used it to assist in setting up a couple of SAT TV dishes in Nthn Europe.
If you want to set up your magnetic compass properly find yourself a Compass Adjuster in Auckland and get them to do you a proper survey and deviation card.
__________________
Cheers,
K1W1
Old 06-28-2009, 09:07 AM   #6
Capt J
Senior Member
I've found that on the smaller compass', many of them are under $100 and it is cheaper and easier to buy a new one as the old one lost it's fluid for a reason. Compasses should be adjusted for deviation for the area you're in otherwise they will be off slightly but have never seen one off more then 10 degrees, you can adjust it yourself with a good handheld compass or gps if you can maintain a steady heading and it's not that difficult to calibrate one yourself. Each boat will deviate a compass slightly just because of the other things installed around it such as electronics or metal items.
Capt J is offline   Reply With Quote
Old 06-28-2009, 12:18 PM   #7
Capt. Bill11
Senior Member
Capt. Bill11's Avatar
http://www.selfmadesailor.com/index.htm?compass.htm&2
http://www.pangolin.co.nz/c-swing.php
Capt. Bill11 is offline   Reply With Quote
Old 06-28-2009, 01:04 PM   #8
K1W1
Senior Member
K1W1's Avatar
Quote:
I think you should brush up on your navigation theory before giving out advice like this.
It is the Variation that changes annually and from area to area not the deviation.
Deviation is affected by the irons and structure in the boat the compass is on not by the area it is in.
__________________
Cheers,
K1W1
Old 06-28-2009, 03:16 PM   #9
Capt J
Senior Member
Thanks for the correction. I meant to say for the boat it is installed in (area meaning area on the boat), and as stated above it should be adjusted for the boat locations variation.
Old 06-28-2009, 03:59 PM   #10
K1W1
Senior Member
K1W1's Avatar
Once again I am surprised by your answers.
How do you "adjust" for variation?
Is not still part of the acronym TVMDC- Timid Virgins Make Dull Companions or True, Variation, Magnetic, Deviation, Compass?
When using a Magnetic compass for real you usually have to work this little equation backwards to get the true bearing.
When I was learning I was also told that you should also regularly take Azimuths to confirm the accuracy of the Magnetic Compass as a whole.
__________________
Cheers,
K1W1
Old 06-28-2009, 04:16 PM   #11
waterman
Registered User
what's in its mineral spirits.
waterman is offline   Reply With Quote
Old 06-28-2009, 04:48 PM   #12
K1W1
Senior Member
K1W1's Avatar
Quote:
Don't be so sure.
Here is Post No two of this thread in case you didn't read the link
http://www.yachtforums.com/forums/44891-post2.html
__________________
Cheers,
K1W1
Old 06-28-2009, 05:19 PM   #13
Blair
Registered User
Thanks guys - not immediately concerned with the issue of 'swinging' the compass to correct for variation due to extraneous metal-related forces nor geographical deviation in that similar context. I have the deviation card -somewhere! That's another story perhaps.
As mentioned I am able to correlate with the GPS on various headings and can adjust/record variation and deviation as in 'swinging'. My query really is that I have seen people with "Northern Hemisphere" handhelds and being told that the imbalance of the needle when used in the far South can cause a 'catching' of the needle which tilts quite a lot and whether this 'extra' error causing factor could also be apparent for Northern fluid filled compasses? Intuitively I think not as the range of tilt in a fluid filled compass seems far greater than the needle has in a slim handheld but I thought I would ask the wise ones.
By the way Kiwi, I can agree that magnetic compasses on a bouncing fizz boat are very much a fall back system these days especially with GPS.
I admit that I have gone over the Kaipara Bar quite deliberately, no accidental crossings as yet, and that it itself is an adventure even in decent conditions - up to 10 metre breaking Tasman Ocean SW swells and 6 knots of tide if you were otherwise stupid about weather or don't pick your tide times! I think the wreck tally at the Graveyard/North Head was something like 100 ships in a 100 years until it was closed as a NZ port of entry. Reputably the biggest harbour in the Southern Hemisphere but no lights or official nav buoys at all these days - good fishing for the good keen bloke/sheila though.
Old 06-28-2009, 08:26 PM   #14
Capt. Bill11
Senior Member
I believe you mean mineral oil.
Old 06-28-2009, 10:20 PM   #15
PropBet
Senior Member
PropBet's Avatar
Somewhere I read it was mineral oil, however have no reference to that.
Google yields a variety of discussions. From alcohol, to ethanol, to oil.
My guess- snake oil.
PropBet is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 04:45 AM.
Click for Christensen
Click for Lurssen
Click for FLIR
Click for Crescent
Click for Moonen
Click For Affinity
