Click for YF Listing Service Click for Nordhavn Click for Ocean Alexander Click for Burger Privacy Matters
16V2000's HONEST OPINIONS!
Discussion in 'Technical Discussion' started by 1CRAZY1, May 24, 2007.
  1. 1CRAZY1
    1CRAZY1 New Member
    San Diego, Ca
    I am looking at spending some big bucks on a boat with twin 16V2000's in it. The motors have 2000 hrs on them and they are 2000yr models. Can anybody offer some info on these motors because I am getting a lot of mixed emotions:confused: Thanks in advance!
  2. Garry Hartshorn
    Garry Hartshorn Senior Member
    A very good performance engine, but like all performance engines they need to be maintained as per specified by the builder, I would suggest as part of the buyers survey that you have a factory trained mechanic do a though inspection, Oil samples, boroscope etc........
  3. faiz
    faiz New Member
    Kuala lumpur
    FYI.
    Engines for Yachts
    Diesel engines for vessels with unrestricted cont. operation Unrestricted continuous rating e.g. Large sailing yachts Engine model 16V 2000 M60
    Fuel stop power ICFN kW(bhp) 800(1073)
    Speed rpm 1800
    Fuel consumption
    at rated power g/kWh 200
    l/h (gal/h) 192.8 (50.9)
    optimum g/kWh 198
    Dimensions and masses incl. gearbox
    Length (L) mm (in) 3110 (122.4)
    Width (W) mm (in) 1400 (55.1)
    Height (H) mm (in) 1405 (55.3)
    Mass (dry) kg (lbs) 4145 (9138)
    Mass (wet) kg (lbs) 4475 (9866)
    Gearbox model ZF 4540
    Transmission ratio 1.2-3.0
    Engine main data
    No. of cylinders 16
    Bore/stroke mm (in) 130/150 (5.1/5.9)
    Displacement, total l (cu in) 31.84 (1943)
    Power ratings classifiable
    Intake air temperature 25°C / Sea water temperature 25°C
    Power reduction at 45°C / 32°C: none
    You can visit www.mtu-online.com for further info.
    tq/brgds
