Click for Rybovich
Click for Burger
Click for Rybovich
Click for Benetti
Click for Moonen
Click for Christensen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > 16V2000's HONEST OPINIONS!
Reply
Old 05-24-2007, 11:34 AM   #1
1CRAZY1
Registered User
I am looking at spending some big bucks on a boat with twin 16V2000's in it. The motors have 2000 hrs on them and they are 2000yr models. Can anybody offer some info on these motors because I am getting a lot of mixed emotions Thanks in advance!
1CRAZY1 is offline   Reply With Quote
Old 05-24-2007, 08:38 PM   #2
Garry Hartshorn
Senior Member
Garry Hartshorn's Avatar
Location: I have an old homestead about 3 hours drive west of Sydney but I am hardly ever there
A very good performance engine, but like all performance engines they need to be maintained as per specified by the builder, I would suggest as part of the buyers survey that you have a factory trained mechanic do a though inspection, Oil samples, boroscope etc........
Garry Hartshorn is offline   Reply With Quote
Old 05-25-2007, 12:18 AM   #3
faiz
Registered User
FYI.
Engines for Yachts
Diesel engines for vessels with unrestricted cont. operation Unrestricted continuous rating e.g. Large sailing yachts Engine model 16V 2000 M60
Fuel stop power ICFN kW(bhp) 800(1073)
Speed rpm 1800
Fuel consumption
at rated power g/kWh 200
l/h (gal/h) 192.8 (50.9)
optimum g/kWh 198
Dimensions and masses incl. gearbox
Length (L) mm (in) 3110 (122.4)
Width (W) mm (in) 1400 (55.1)
Height (H) mm (in) 1405 (55.3)
Mass (dry) kg (lbs) 4145 (9138)
Mass (wet) kg (lbs) 4475 (9866)
Gearbox model ZF 4540
Transmission ratio 1.2-3.0
Engine main data
No. of cylinders 16
Bore/stroke mm (in) 130/150 (5.1/5.9)
Displacement, total l (cu in) 31.84 (1943)
Power ratings classifiable
Intake air temperature 25°C / Sea water temperature 25°C
Power reduction at 45°C / 32°C: none
You can visit www.mtu-online.com for further info.
tq/brgds
faiz is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 01:14 AM.
Click for Oceanco
Click for Lurssen
Click For Dockwise
Click for Shadow
Click for Broward
Click for Quantum
