Click for YF Listing Service Click for Ocean Alexander Click for Burger Click for Delta Click for Westport
Fuel polishing
Discussion in 'Technical Discussion' started by JoeQ, May 7, 2007.
  1. JoeQ
    JoeQ New Member
    Scotland
    I want to install a fuel polishing system on my boat. Something that can also be used as a fuel transfer system between 2 tanks. Space is fairly limited so I don't think the Alfa Laval type would fit.
    Any recommendations please?
  2. Scryer_360
    Scryer_360 New Member
    Missouri (of all the worst places for a motor yach
    I think we will need to know what kind of boat we are dealing with here. That will give you more accurate answers.
  3. K1W1
    The guy has a Cheoy Lee 63 with twin 3208 Cats in it.
  4. JoeQ
    JoeQ New Member
    Scotland
    Yes, I probably should have said. As K1W1 stated, it's a Cheoy Lee 63 with twin 3208 Cats. Twin tanks of 750 gal each. 12 volt DC system with 110/220 volt AC.
    Existing primary filters are single Racor 900's per engine.
    Any advice please?
  5. K1W1
    There are small footprint Centrifugal Separators available.
    If you are really stuck for space Joe you could and should look at fitting a Coalescing Type Filter into the line between pump and tank such as
    http://www.parker.com/EAD/displayCa...ER/SEPARATOR VESSELS&viewtype=1&sMode=Details
    I am not personally familiar with the layout of the tanks on your boat and don't know if you have a Day tank as such or if each engine sucks out of it's own tank.
    If you don't have a problem with microbiologic growth in your fuel now it may be prudent to add some biocide when you fill up. The " fuel bug" can grow just as well in cold northern climates as the tropics. this is shown by the fact that it used to affect the lube oil in some North Sea Oil Field Vessels that sailed out of Aberdeen.
    If you can send me a rough drawing of your Fuel System I will try to draw you a simple way to add either a Seperator or a Filter system to your engine room.
  6. JoeQ
    JoeQ New Member
    Scotland
    Hi K1W1,
    Thanks for your assistance. I don't have a day tank and there's a good manifold arrangement on the forward bulkhead for drawing and returning fuel to either tank. I've sent you a PM with a link to a tiff format image of an original shipyard drawing with the piping arrangements.
    I've removed the stb generator so have a bit of extra space. I can also use the manifold valves that supplied this gen set to feed the polishing system.
    I will add some biocide soon once I decide which type to get, but that's another question!
    Cheers,
    Joe
  7. K1W1
  8. balboa
    balboa Guest
    off-line filtration
    Have you thought about 'off-line filtration?
    With a system like this, you won't need a separator anymore and ALL your fuel will be clean.
    The company's website is: http://www.cjc.dk/ccj-filter-division
    Good luck
    Thorwald Westmaas
