Click for Nordhavn Click for Burger Click for Ocean Alexander Privacy Matters Click for Westport
Thrust bearing question
Discussion in 'Technical Discussion' started by tildes, May 2, 2007.
  1. tildes
    tildes New Member
    Vigo (Spain)
    Engines
    Do anybody know if she has the thrust bearing inside the gear box or has an independent thrust bearing?
    Archnav.de, funny how i have never seen these pictures on here yet. Such an extensive collection of Aposie photos, they really do suffice. Thanks.
  3. K1W1
    Tildes, Welcome to Yacht Forums
    That is an unusual question for a first post at YF?
    The Prop shaft Thrust bearings would be mounted separately to the gearbox and the Crankshaft Bearings would be in the engines themselves
  4. tildes
    tildes New Member
    Vigo (Spain)
    Thrust bearing
    Hi K1W1,
    It is an unusual question, but I am building a 70 m motoryacht and I am discussing with the noise and vibrations experts this matter and they do not agree between themselves; so, I am looking for information on different forums about similar ships.
    Thanks for your help.
  5. Innomare
    Innomare Senior Member
    Tildes,
    You can either have the gearboxes take up the thrust (flexible coupling between gearbox and M.E.) or you can have an independent thrust bearing and a flexible coupling between the thrust bearing and the gearbox+main engine.
    The latter is the solution with less noise & vibrations, but also a bit more costly and the drivetrain becomes a bit longer.
    Good luck!
    Bruno
  6. tildes
    tildes New Member
    Vigo (Spain)
    We have the added problem of a controlable pitch propeller. The solution with the thrust bearing doen't allow us to put the hydraulic power pack on the gear box, because the flexible coupling. We are now studying the use of very soft flexible mountings in the main engine and hard flexible mountings (able to take the thrust) in the gear box.
  7. Innomare
    ... and a flexible coupling between main engine and gearbox I suppose.
    With some gearboxes you can have a PTO that exits on the top. Then it's not in the way of the thrustbearing or flexible coupling. Which gearboxes are you using?
    The solution you propose works as well. It'll be only a few decibels difference with a separate thrust bearing. (you wouldn''t notice the difference, but it all adds up)
