Click for Burger Click for Ocean Alexander Click for Delta Click for Glendinning Click for Cross
Marina electrical connections
Discussion in 'Technical Discussion' started by mm74, Apr 13, 2007.
  1. mm74
    mm74 New Member
    Ancona
    Hi all,
    I'm new in this forum.
    I have a question: in your experience what kind of electrical connection and what power (kW) is possible to find in the various Marina?
    I mean: in Europe you can find 230V single phase and 400V 3-phase 50Hz with different power for example.
    Thank you
    MM
  2. K1W1
    In Europe you are getting 50 Hz Power from the normal supply no matter if it is 3 phase 400V or single phase 230V.
    Single phase power is normally one phase of the three phase supply and the neutral.
    Previously the 3 Phase power here in Europe was 380V if you divide this by 1.732 ( the square root of 3 ) you get the sngle phase voltage. Inthis case 380/1.732 = 219.39 or what would normaly be called 220V Single phase.
    400/1.732 = 230.94 or 230V Single phase and for the Australians and New Zealanders where the 3 Phase is normally 415/1.732 = 239.60 or what is commonly referd to as 240 Single phase
  3. techmati
    techmati Senior Member
    Athens, Greece
    what is the common max current available though. is above 50 amps to be expected?
  4. K1W1
    That's not an easy one to answer.
    You will find vaiation in marina to marina ad even sometimes in diferent loation in the same marina the current and plugs differ.
    I a talking about Eurpoean Power here:
    Single Phase is normally 16 or 32 Amp
    ThrEe phase can vary but would normaly start at around 32 then jump to 63 and then it s all over the place up to about 600 Amps on a couple of berths.
  5. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    mm74:
    Check with your local electrical shop.
    There are devices that will convert anything that the dock supplies to what can work safely for your vessel.
  6. yotphix
    yotphix New Member
    Southern California
    Although in some cases this may mean plugging into two or more outlets to get adequate supply. (I am currently plugged into two 220v 50 amp outlets to get the min 75amps I need!)
  7. Ju52
    Ju52 Senior Member
    Frankfurt
    The energy companies are happy if you use more power. So in europe the acceptable voltage is between 180 and 240 volts. Mostly you get the 240 because the used energy depends from the square of the voltage and so you pay more to the companies. :-(
    for 3 phases you have then 240 * 1.732 = 415 volts ...
  8. mm74
    mm74 New Member
    Ancona
    Good morning,
    thank you for all the reply.
    In particular the answer of K1W1 is what I was looking for.
    I need this information in order to better dimension the cable for new yacht and to choose 1 or 2 shore connections.
    Do you have any suggestion for US marina?
    Bye
    MM
  9. K1W1
    The US is a whole different ball game.
    From what I remember you can get up to 100 Amps of Single Phase, 220V is often referred to as Two Phase.
    Your best bet would be to ask a few marinas where you pans to cruise to get an idea of what they offer. Tell them you want to book a berth when you are in the area and you are checking the facilities.
    Originally By Ju52:
    "The energy companies are happy if you use more power. So in europe the acceptable voltage is between 180 and 240 volts. Mostly you get the 240 because the used energy depends from the square of the voltage and so you pay more to the companies. :-("
    I would be very surprised if the Energy Companies could supply you in Germany or anywhere else in Europe at 180V ( 311V 3 Phase)a lot of Under voltage protection devices would be tripped well before this and there would be a lot of blown fuses and or damage in and to appliances drawing much more current than they are designed to do. When Voltage Drops Current rises and vice versa.
    I stick by what I said about 400 being the norm here in Europe( I am in Germany), I just measured two single phase sockets 1 in my Office and 1 in a workshop using a recently re calibrated Fluke 87 DMM.I found 230.4 in the office and 230.9 in the workshop proving the info I posted earlier 400/1.732 =230.94
  10. mm74
    mm74 New Member
    Ancona
    thank you K1W1 for your prompt reply.
    Concerning the discussion about tension, I can tell you that in Italy, as K1W1 says, we have 230V single phase and 400V 3-phase.
    The contract range, for single-phase, is 230V +/- 10% (207V-253V).
    I suppose is due to the normal distribution schema: from a 3-phase they take 1 phase and neutral and they goes, so, in order to cover the maximum extension, they raise a little the voltage at the beginning to compensate the normal tension losses depending on the wire length.
    Bye
    MM
  11. K1W1
    As I wrote in my first post on this subject.
    The biggest thing to check when setting up a system on board yourself is phase balance, Don't take all your single phase loads off the same leg of 3 phase.
    This is especially important for setting up generators for parallel running. If the heaviest loaded phase has the CT that senses Genset load you will be plagued with starts and stops with underloaded gensets.
  12. mm74
    mm74 New Member
    Ancona
    Of course.
    I was speaking about normal installation in houses, not in boat. It was an example of distribution to explain the reason of the tolerance for tension values.
    Bye
  13. Ju52
    Ju52 Senior Member
    Frankfurt
    I'm working in a bigger IT area ... 180V is a theoretical minimum what you should get from the power lines. I never measured less 210Vin Germany.
    If you have a static restistance R then the power is U * I = U * U / R. In practice an enginge sucks more current to deliver the needed power...
  14. K1W1
    I would like to see the contract to supply where the Power company states that a 230V Single Phase supply can go as low as 180 V even theoretically.
    If you are measuring the power out of any type of power supply, power conditioning, soft start, drive unit then your numbers can vary greatly momentarily.
