Click for Heesen
Click for Lazzara
Click for NorthCoast
Click for Quantum
Click for Broward
Click for Moonen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Help? Custom FiberGlass Waste Tank...
Reply
Old 04-08-2008, 06:15 AM   #1
mybuoys
Registered User
I have a wast tank in my 42 Jefferson Sport fish that has held it's last piece of waste. I am switching to a vacuflush system, the question is , what do I do with the tank?? It is an origonal tank that was bild in between the stringers below the deck and sits 2" above the bilge. The tank bottom is like swiss cheese no large holes or cracks but the entire bottom is leaking. Is there a product that I can pour in the tank to re seal the entire bottom of the tank or should I cut the visable end out to sanitize the tanks so it dosn't contaminate the boat???
mybuoys is offline   Reply With Quote
Old 04-14-2008, 11:54 PM   #2
Spinnaker
Registered User
Doesn't the vaccu flush have a tank? Have you thought of a place? Reason for asking is that I was wondering if you will have to reuse the same area the old tank is in.
Spinnaker is offline   Reply With Quote
Old 04-15-2008, 05:26 AM   #3
mybuoys
Registered User
Yes, My main concern is what I needed to do with the old tank. The new system had only a 10gal tank and I was going to "Y" in a macerator to push to the old tank for additional storage. I ended up cutting a hole in the top and a one in the bottom to completely sanitize the old space. I was told not to cut it completely out as some tanks are configured structurally into the bow. Thanks for the reply
Sam
Old 04-15-2008, 10:35 AM   #4
AggieH2O
Registered User
If the tank was designed to help reinforce the structural integrity of the vessel, then it is doing no good in its current condition. I would remove the old tank and fabricate a composite brace to replace it. If it is not used as a support, I would just cut it out. Once the glass gets saturated, it is hard to dry it out for re-usage. Just my opinion.
AggieH2O is offline   Reply With Quote
Old 04-15-2008, 03:06 PM   #5
Spinnaker
Registered User
Quote:
I completely agree.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 12:52 AM.
Click for Lazzara
Click for Burger
Click for Benetti
Click for Nautical Structures
Click for ISA
