Click for Christensen
Click for Horizon
Click for NorthCoast
Click For Dockwise
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Opening portholes
Reply
Opening portholes
Old 12-01-2006, 12:34 PM   #1
Francois
Registered User
Lightbulb Opening portholes
Hi everyone. As you know I am busy fitting out a 26 m. In all my time I have worked on yachts in all the cabins you have ventilation through opening ports. But on this project their is no ventilation while under way or while at anchor somewhere in the tropics where it hot and humid.
Sounds like they will have to rely on the aircon 24/7. It might be ok if you have shore power but hey its not like it should be.
I even asked if some kind of dorado vents at least would be fitted. What do you think? I would like opening ports on my boat one day. Fresh air at anchor or run that baby and count your pennies.
As a woodworking craftsman it makes me wonder. Man that yacht will be hot .
Have Fun
Francois
Francois is offline   Reply With Quote
Old 12-01-2006, 01:17 PM   #2
AMG
YF Moderator
AMG's Avatar
As you say, hot and humid, is actually not what you want to have inside by opening up the boat. Not good for the woodwork, fabrics, carpets or perhaps artwork on the walls.
Air Condition is doing what it is named after, taking away the humidity and stabilize the temperature inside. Normally half of the air is from outside and the other half is recirculated so it will not be too dry or too damp, still oxygen enough for you to breath...
If the system is designed so you can shut down half of the compressors and run a smaller genset, which you normally have to anyway, the cost will not be too high...
__________________
Designing the future classics, today.
Lars Modin Design
AMG is offline   Reply With Quote
Old 12-01-2006, 05:13 PM   #3
Loren Schweizer
YF Associate Writer
There might be a happy medium to be had here.
Depending on how well the hull is insulated, one could emulate the certain owners of a 78' motorsailer I am familiar with in that they fired up the air conditioning late in the afternoon for a period of time and then relied on small Hella fans strategically located throughout the vessel to maintain comfort.
Loren Schweizer is offline   Reply With Quote
Old 12-01-2006, 05:25 PM   #4
C4ENG
Senior Member
C4ENG's Avatar
Any other yacht that I had worked on or been on has always been the same........
When the A/C is down, the party is over.
C4ENG is offline   Reply With Quote
Old 12-02-2006, 10:16 AM   #5
Francois
Registered User
Thanks guys and looks like other yachts have the same situation.Last week I went on a Ferretti to install an ssb radio into the dash and notice the samething.I did not go into the owners cabin but the main lounge had fixed windows.According to the skipper the aircon runs 24/7.
Francois
Old 12-02-2006, 03:30 PM   #6
techmati
Senior Member
techmati's Avatar
depends also on the nationality of the owner, cruising grounds. If you think of some hot countries they are used to AC 24/7. Its not something i like personally. There have been quite a few refits to enclose the sun deck for the reason that the owner wants AC there.
I was recently on a cruise ship being refit. They had installed alarms so that when the door window was opened to the balcony the alarm would sound and the guest would close it quickly. What was the reason for that? Well if many guests left their windows open the AC for the ship would have to work harder and this would make unneccessary costs for the owner.
__________________
if it floats shoot it with a canon.....
techmati is offline   Reply With Quote
Old 01-07-2007, 01:46 PM   #7
nilo
Senior Member
alternative to airconditioning
in the med we hardly use air-conditioning, because it does not feel good to move between cold and hot during the day and all the cabins have opening port holes, so good nice air for the night, unless it is a very hot night. then, we operate the aircon to cool down the interiors just before the night.
it is a good idea to add sensors for open port holes, not mainly for the air-conditioning, but to ensure that none is opened by novice quests during the cruise. if you are going to take long cruises, and the fresh air from air conditioning is not enough, then you can add a fresh air system, where you will pump in treated (dehumidified) air to the cabins.
nilo is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 12:26 AM.
Click for Nautical Structures
Click for Oceanco
Click for Heesen
Click for Dyna
Click for Queenship
Click for Moonen
