Click for Abeking Click for Westport Click for JetForums Click for Cross Click for Ocean Alexander
Low Gear Oil Pressure
Discussion in 'Technical Discussion' started by rocdiver, Dec 6, 2006.
  1. rocdiver
    rocdiver Senior Member
    Ft Lauderdale, Florida
    Good Day All!!
    I have recently taken over a 104' Broward, 1984 with 12v92a Detroits. The crew changover wasn't exactly harmonious so I didn't get a lot of inside scoop from the previous Captain.
    I recently took her out for a little spin and got "Low Gear Oil Presure" alarm on the starboard DDEC system. I never lost any propulsion, as far as I could tell, and the gear oil levels are perfect.
    When I took her back to idle in neutral the gear oil pressure dropped to zero as opposed to about 100 on the port side. Re-engaging her got me up to about 80.
    Anybody with similar experience that might point me in the right direction?
    Many thanks in advance for any help and . . .
    HAPPY HOLIDAYS EVERYBODY!!!!!
    ROCKY
  2. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    If you've been good, maybe it's just related to a hung-up diverter valve in your Twin Disc gear, assuming they're not ZF.
    Did you already check the sender against a mechanical gauge?
    You will still need to get real expert advice from a tranny mechanic, plenty of whom are in your area.
  3. rocdiver
    They are ZF Marine Gears
    OOPS!! Me bad, I forgot to mention the Detroits are coupled to Z-F Marine Gears . . .
