Click for Westport Click for Glendinning Click for Abeking Click for YF Listing Service Click for Burger
Loss of efficiency due to prop angle
Discussion in 'Props, Shafts & Seals' started by wdrzal, Nov 10, 2006.
  1. wdrzal
    wdrzal Senior Member
    Question? why do most boat builders still use the method of pitching the motor a few degrees and running a straight shaft with the prop pitched a few degrees losing some efficiency because its not perpendicular to the hull ?????
    By using a constant velocity joint so the prop could be mounted 90 degrees or what ever angle that gives the best efficiency?????
    Is there a reason I,m unaware of????? ,as marine constant velocity joints are already in use on surface drives !!!!!!!!
    Talk about slow to change old ways of Thinking !:confused: While above water what you can see has the coolest ,newest designs !!!!!
  2. nano-J
    nano-J New Member
    IPS Drives
    check out the new LAZZARA LSX. Witness the death of straight drives!
