Click for Burger Click for Walker Click for Nordhavn Click for Abeking Click for Westport
The Low down of Mooring lines?
Discussion in 'Technical Discussion' started by Yacht News, Oct 19, 2006.
    This is something i always wanted to know about. Why yachts, or most yachts while alongside, have their mooring lines so slack. Do they become slack or they just purposely ties them like that. ...Any ideas to help me?
  2. Billy1119
    Billy1119 Senior Member
    Tampa, FL
    Well, it depends on the tides mostly. When you tie up the boat, you have to have the lines adjusted to allow for the hight change in the tide without making the lines too loose or too tight. This is dependent on many things, including the length of the lines between points were they're secured, the height of the dock/cleats relative to the waterline (and the deck), the amount of tidal change, etc. So, most of the time they are (should be) tied with enough slack to allow room for tidal increases. At high tide, you would generally want to tie the vessel tighter so when the tide goes out, the lines are not excessively loose. There are certain situations where this can be difficult, and the best way to keep things in place is frequent adjustment. Most of the time, however, if done correctly, you can have enough line for the tide, but not more than necessary.
    Also, over time, especially when wet and tight (or have tension put on them), the lines will stretch on their own. They should be adjusted as necessary if this occurs to keep things in place properly.
    On the other hand... I have often seen boats large and small tied up with poorly adjusted lines where it seems to me they just didn't know what they were doing. This is far too common from what I've seen...
    Wow, thanks for you info, Bill...so how comes then cruiseships tie with so much tension then...i know i should not be comparing yachts and cruiseships but i see this....some container ships too...tide woulndt be a factor with these vessels too?
  4. Billy1119
    Tampa, FL
    No problem. :)
    While I'm not cruse ship expert, here's what I suspect. The tides certainly affect them as well, but it doesn't play as big of a role because of the extreme length of the lines. When the tidal change is 3-4 feet, and the lines are tied onto the boat 50 feet from the pier, the tidal change has a relatively smaller affect on the line tension. In addition, I suspect the difference can just be stretched out of those lines because of their length (although I don't know if that's what they do).
    It would be important to keep the ship carefully in place relative to normal boats largely because of the importance of it sitting still. Think of the passengers coming on and off, and cranes (or whatever) loading and unloading cargo, etc. If a slight breeze were to come along and it wasn't tied tight, someone or something could get hurt/damaged... There's also a lot more momentum that can be created when those suckers move around and could cause more damage.
    This is what I suspect. In addition, because of the man power on these ships, perhaps they adjust the lines frequently enough to keep them tight, but not too tight (not forcing them to stretch).
  5. Innomare
    Innomare Senior Member
    Hi Yachtluver,
    modern cruiseships are normally equipped with automatic mooring winches. You can set the (range of ) required tension and they will pull in or let out the mooring lines to have the correct tension in the lines at all times.
    Bruno
  6. Yacht News
    Thanks for your information Bill and Bruno, i know that cruiseships have Mooring winches.and even if i didnt know...i would be safe to assume there is some machinery being enabled to keep the lines so tight. but i is just that i didnt know how comes they were so tight in relation to the tidal change...I am an avid cruiseship enthusiast...just i didnt know that part.
    What about the thicknesses of these ropes.....i remember when i was alot smaller and my dad used to take me into the Bridgetown harbour, i would see ships with lines that were almost or more than 7-8 inches wide... now yachts and ships use lines that are so small as compared...what are these new lines being made of that they can be so small now...nylon?
  7. Yacht News
    can anyone help me with the above question or i have to do my own research;)?
  8. Billy1119
    Tampa, FL
    Yeah, sorry about that yachtluver. Sometimes we just get tired of answering questions for certain individuals. ;)
    You are correct that one of the most popular materials for lines is nylon. I honestly don't know if that's what the big ships use, but I would assume as much. The two main variations are three-strand nylon and braided nylon lines. Three-strand generally will stretch more and isn't quite as strong as the braided, which tends to stretch less than three strand. Three-strand is cheaper, however, and is often used for anchor line on smaller boats because it stretches more, and can be easily spliced.
    Some other materials are polypropylene (normally yellow), which serves its purpose, although you wouldn't want to use it to tie up your yacht. This kind of line floats. Dacron line will not stretch, but I don't know much about its other properties. Then there's the good ol' natural fiber, which I suspect is what the large 7-8" lines you mentioned were made of. This is not as strong as nylon and will rot much more easily.
    Hope this answers your questions. I was, of course, kidding about getting tired of answering your questions. :) Time for bed now, have a good night!
  9. Yacht News
    LOL...ok...i once thoughth that the thicker the rope...the stronger ( that was when i was 8 years old)... No wonder the thick ropes (natural fibres as you call them) pop so many times in the past....I know of a guy that was injured by one of those thick ropes that broke from a cruiseship here.
  10. Garry Hartshorn
    Garry Hartshorn Senior Member
    Many but not all large ships use wire cable especially if they have a self adjusting system.
  11. Yacht News
    Yea i realise Garry..
    Now what about actual mooring with these lines. On yachts that berth stern first especially at marinas it is common to see them 'crossing' lines like in an X and then using two other lines that go outward from the main deck at the stern. Is there any particualar reason? why this method of tying?
  12. Garry Hartshorn
    Well the lines going directly from the tacht to the dock hold the vessel in and the crossed lines, springs restrain the vessel from surging along the dock.
  13. Yacht News
    SO what happned here with the Amels GU lines in this photo here taken by fellow member Stroepel. The aft line from the Port side is taught but the line a beam on the Starboard side is Very slack and looks to be serving no purpose really?........http://sports.webshots.com/photo/2884072270095209377AHlfFe
  14. aeronautic1
    aeronautic1 Member
    The second "crossing" stern line is a back-up line and therefore does not need to be taunt. If you were tying up a 20 million dollar yacht, you would put out a few extra lines as well.
  15. Yacht News
    True True Aeronautic1---I thought GU cost more than that...None the less a great design by Amels...I wish they would build more yachts along a design like Gu.
    Anyhow, my next question.....or more out of curiosity. Seeing numerous pics of yachts berthed at the IYCA....marina in Antibes France with the yellow mooring buoys...I see the larger yachts such as Carinthia VII, Constellation(stargates' sister) and so on tied onto the buoys. Out of curiosity, they usually have to let out alot of rope from the midships rope eyes( dont no the correct term for them) to tie to a buoy that is off to the front. Is this as stable and secure as dropping anchor at the bow?..I dont know if i am getting what i want to ask come out...
  16. K1W1
    These are commonly known as Fairleads
  17. Yacht News
    Thanks K1W1...There are called Fairleads on all ships or just yachts?
  18. K1W1
    I am pretty sure this term is used on any type of vessel.
  19. aeronautic1
    aeronautic1 Member
    Chocks and Fairleads
    chock (n)
    Definition: 1) Fairlead. A fitting mounted securely to the deck or cabin top through which lines are led. 2) A deck fitting used to secure moveable gear.
    fairlead (n)
    Definition: A block, padeye, ring or any other kind of gear which controls the path of a ship’s running rigging, and keeps it from fouling or chafing. Such as a turning block on a sailboat's sheet.
    A chock is a fairlead, but a fairlead is not a chock, unless of course it's chockablock.
  20. airship
    airship Senior Member
    French Riviera...
    That photo is typical of the philosophy that "the more lines you have out, the happier you'll feel..."?! You can't see what's going on with the lines leading out from the bow in the photo, but anyway, let's remind ourselves what a mooring line is supposed to do:
    1) Limit forward movements of the yacht (ie. stern lines)
    2) Limit astern movements of the yacht (ie. bow lines)
    3) Limit sideways movements of the yacht (ie. breastlines)
    4) Limit forward, astern or sideways movements of the yacht (ie. spring lines)
    When alongside, ideally, you'd have mooring lines to limit movements in all directions leading out from both the bow and stern of the yacht. In yachtluver's photo, that Amels appears to have just 1 spring line (to limit astern movement) plus 3 breast lines (1 of which is so slack as to not be doing anything at all except to catch fishhooks from nearby fishermen...). :rolleyes: If I were the skipper, I might have preferred:
    1) a stern line to limit forward movement from the innermost fairlead (ie. the 3rd or closest fairlead to the centre of the yacht on the port side) leading out to the mooring bollard farthest from the yacht's stern
    2) a spring line to limit astern movement from the fairlead on the extreme corner on the port side leading out to the bollard on the quay / pier closest to the yacht's mid-section
    3) a breast line to limit sideways movement from the fairlead on the extreme corner on the starboard side leading out to the same bollard as in 1)
    In this particular situation, the extremely short breast line leading out from the middle fairlead on the port side may as well be a steel bar welded onto both the yacht and the quay... :D
    By all means, "double-up on lines" if weather or tidal conditions demand, but at least ensure you arrange whatever lines you have out purposefully...?! :)
    Obviously, a mooring line is just one part of a complete mooring system...whose components consist of the mooring bollards / bitts / cleats, fairleads and rollers or whatever on the yacht, the mooring line itself and the bollards / bitts / cleats or rings on the quay etc.
    Severe injuries and even fatalities have occurred to passengers / crew or those on the quay due to the failure of one or more components, on yachts as well as in commercial shipping... :eek:
    Before moving on, I'd just like to address another observation / question from yachtluver
    The whole point of having these buoys at marinas like they do at the IYCA is so that yachts do not have to drop their anchors...! Actually, the problem is not actually dropping the anchors, it's about security and convenience, whilst other yachts "over whom you've dropped your anchors and chains" attempt to leave their berths, possibly dislodging your anchors and then when you yourself wish to leave your berth, and have to call in a diver "to untangle the mess lying on the seabed"...?! :eek: As for which particular fairlead the mooring lines lead out from the yacht to the buoys, well, it's all about purpose...?!
    Back to mooring lines in general, for superyachts...
    They're made of polyamide (nylon is the registered trademark of DuPont) or polyester, are of either double-braided or squareline (8 or 12 strand) construction and are usually spliced with a soft eye at one end. Rarely does one see 3 braided ropes used on yachts over about 25m (80ft).
    Let's take a typical 50m (180ft) motoryacht's set of mooring lines:
    Ø40mm double-braided or squareline, polyamide, with Ø75cm soft leather-protected eyes,
    1) 4 x 20m
    2) 2 x 30m
    3) 2 x 40m
    Depending on the classification society, you might also be required to carry a suitable tow-rope (a humongous coil of rope upto 200m. long and usually floating polypropylene squareline usually stowed (and forgotten) in the forepeak...which I'd recommend being cut down into say 2 x 100m lengths and used as the bow lines for when you go into somewhere like the IYCA and are allocated a 100m berth (and charged for it)... :eek:
    Why polyamide (nylon), polyester or polypropylene? Here's some typical comparisons:
    (all Ø40mm - just over 1 1/2")
    Polyamide double-braided or squareline construction: breaking load: 40,000 daN (40,000kg to you and me); weight: 99kg per 100m; elongation (stretch) about 15-20% at 50% load; "a finished 30m mooring line weighs about 33kg".
    Polyester double-braided or squareline construction: breaking load: 32,600 daN (32,600kg to you and me); weight: 121kg per 100m; elongation (stretch) about 10% at 50% load; "a finished 30m mooring line weighs about 40kg" . Granted, polyester has superior abrasion characteristics compared with polyamide, but is it really worth the additional initial cost for this and the fact that it has a lower breaking load...? I don't really think so all things considered, especially when your average superyacht owner likes to have "good-looking lines", replaced every 3-5 years...
    Polypropylene squareline construction: breaking load: 26,500 daN (26,500kg to you and me); weight: 72kg per 100m; elongation (stretch) between 20-30% at 50% load; "a finished 30m mooring line weighs about 24kg". It also floats, compared to polyamide and polyester, which do not...!
    So why polyamide?! Its' strength and weight advantages easily outweigh the wear characteristics of polyester lines. Provided the eyes and other chaffing points are suitably protected, I'd plump for polyamide (nylon) lines all the time. However, polypropylene lines will float, which makes them a lot easier to handle in some situations like when you're trying to get a long line out onto a dead tree (?!) in a secluded anchorage without swinging room somewhere in Turkey for example. Or tying up to the buoys at the IYCA...?!
    But what do you do if you own a 86m yacht?!
    Well, it's worth bearing in mind that unless you have multiple "California governors as deckies", it becomes impossible to correctly manually handle anything over Ø44mm mooring lines. A 30m Ø48mm polyamide mooring line weighs about 47kg, a polyester one about 58kg. The lines would probably not go around the mooring bollards / bitts / cleats, fairleads and rollers or whatever on the yacht, let alone the mooring capstans...?! So ensure that your new yacht has multiple over-engineered mooring bollards / bitts / cleats, fairleads and rollers so that you can satisfactorily double-up smaller lines...!
    A short aside: commercial shipping nowadays is increasingly converting from use of steel-wire mooring lines to the use of synthetic alternatives like Spectra, Dyneema etc. which offer far greater breaking resistances for the same diameter. In fact, double-braided synthetic mooring lines are these days the preferred method when tying up your average 250,000 ton oil-tanker to its' offshore berth.
    Another aside: a few ex. sailboat skippers who've moved onto (better-paying with bigger cabins etc.) jobs on motoryachts have brought along a new phenomenon which entails using very small (but extremely strong though not stretchy) Spectra and Dyneema type lines when first tying up, to be replaced by the more traditional (and bigger) polyamide mooring lines afterwards because they're so easy to handle (even by Nicole Kidman-lookalike stewardesses)...?! :)
    Lastly, all the "traditional-looking" ropes one comes across these days (ie. the ones that look like hemp) are more likely to be of polypropylene construction: apparently it's because cultivating the plant that produces the original raw hemp material has inexplicably become illegal... :cool:
    So you think I appear to be quite knowlegeable on the subject of mooring lines huh? Well, that's because once upon a time (a long time ago and in a far off galaxy), I was on the foredeck of a 40m yacht, had sent out the heaving line and was watching the mooring line being retrieved through the fairlead from the dock, until the end ran out as well...it was a bit short one decided afterwards?! :eek:
