Click for Queenship
Click for NorthCoast
Click for Horizon
Click for Dyna
Click for Quantum
Click for Broward
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Mega Yacht Anchors
Reply
Mega Yacht Anchors
Old 10-21-2006, 08:02 AM   #16
captroynsteph
Registered User
What ever happened to swimming from a yacht. Can't exactly do that with two big meat cleavers swinging under the transom. I can't imagine the prop wash would be very helpful with many of the water toys that yachts are carrying these days either.
captroynsteph is offline   Reply With Quote
Old 10-21-2006, 08:14 AM   #17
Billy1119
Senior Member
Billy1119's Avatar
Quote:
I agree, it could certainly complicate things! I would suspect when keeping the boat in place, the prop wash would be minimal, just because of the minor adjustments likely necessary. That depends on a lot of factors though... I agree though - I wouldn't want my kids (when I have some) swimming around with those props spinning.
Hey, 100th post!
__________________
Bill
84' Sunseeker Manhattan
Billy1119 is offline   Reply With Quote
Old 10-22-2006, 06:45 AM   #18
Garry Hartshorn
Senior Member
Garry Hartshorn's Avatar
Location: I have an old homestead about 3 hours drive west of Sydney but I am hardly ever there
The basic concept of the system has been around for quite a while I beleve the original system used on oil rig tenders utilised transponders mounted on the oil rigs for the position information. But back to the original question, I do not see that it can be used as a replacement for anchors.
Garry Hartshorn is offline   Reply With Quote
Old 10-22-2006, 09:30 AM   #19
Billy1119
Senior Member
Billy1119's Avatar
Quote:
Originally Posted by yachtluver
ok, so now what about the kind of anchors. For the small yachts they use some kind of spade looking anchor for sandy bottoms and graveled bottoms.....the mega yachts use the heavy 300-600 KG anchors....what determines what anchor a yacht uses other than size of the yacht..?
Well, you kind of answered your own questions. Other than size, the primary thing that determines the type of anchor is the bottom it will be used in. Some simply hold better than others in certain bottoms. Some would get destroyed in other bottoms - for example - you wouldn't want to use a danforth (works well in sand) in the rocks, as it could get mangled and be difficult to bring up. Not to mention it may not hold well, if it gets hung.
__________________
Bill
Old 10-22-2006, 03:11 PM   #20
YachtNews
YF News Associate
YachtNews's Avatar
A danforth?.. that is the name for the spade looking anchors?
Old 10-22-2006, 03:32 PM   #21
K1W1
Senior Member
K1W1's Avatar
Here is an example of different types of smaller anchors:
http://www.ukdivers.net/boats/anchors.htm
and one for the larger ones
http://www.blueoceantackle.com/hhp_d...pe_anchors.htm
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 10-22-2006, 05:17 PM   #22
YachtNews
YF News Associate
YachtNews's Avatar
Hey, thanks for the links....ur a good help.
Old 10-23-2006, 04:39 AM   #23
Innomare
Senior Member
Innomare's Avatar
anchor sizing
The size of the anchor is based on the equipment number. This number is calculated from a formula taking into account: total displacement (for influence of the currents) and the windage (area of the yacht above the waterline subject to the wind). For the windage, the area as seen from the bow counts twenty times as much as the area seen in profile, which is quite logical.
Every class society has their own tables giving appropriate anchor sizing with regards to the equipment number, taking into account certain reductions (anchor types, number of anchors, service restrictions, etc.). While for ships these rules are practically the same in all class societies, for yachts every class society has their own mind.
For boats < 24 m, there are different rules (CE, e.g.).
PS. Even with gyrocompasses and gps, we still have magnetic compasses all around. I guess it would take forever before a simple and useful system like an anchor would dissapear from ships/boats, even if they were only used in extreme emergencies.
__________________
Naval Architect - Owner's Representative - Marine Surveyor
Innomare is offline   Reply With Quote
Old 10-23-2006, 08:45 PM   #24
YachtNews
YF News Associate
YachtNews's Avatar
Detailed explanation there Innomare.thanks........When they say ' stud linked' that just means that the oval ring has a metal piece in the middle in a horizontal manner? Just making sure what i think is the right thing is the right thing...or wrong
Old 10-24-2006, 12:53 AM   #25
K1W1
Senior Member
K1W1's Avatar
Yes, you are right.
Here is a link that shows a variety of chains and shackles etc asociated with Anchor Chains
http://www.h-lift.com/anchorchain.htm
__________________
Cheers,
K1W1
Old 11-09-2006, 11:31 AM   #26
YachtNews
YF News Associate
YachtNews's Avatar
Hey i just remembered about the metal lines that we all saw on Oceanco's Amevi bulb. I think i remembered some person syaing that they were there to protect the bulb from the anchor chain. How comes then....we do not see it on many other bulbed yachts and further more why not on cruiseships or bulbed cargo/containerships. I think this may nullify the purpose of these lines. Are you sure they are not for hydro dynmaics or something to that effect?
Old 11-09-2006, 11:48 AM   #27
Innomare
Senior Member
Innomare's Avatar
I am quite sure they're not for hydrodynamics. I see them doing more wrong than right in that respect. It's not like on a planing hull where you can have spray strakes because you want the flow to separate from the hull at a certain point. On a bulb, you don't want the flow to separate.
Why some ships don't have them is a tougher one... Maybe because their anchor pockets are further aft. Or because they hardly ever spend time on anchor and don't want the hydrodynamic penalty. Or they have thicker plating in the bulb...
Why do some cars have plastic guard stripes on their doors and others not?...
__________________
Old 11-09-2006, 01:03 PM   #28
YachtNews
YF News Associate
YachtNews's Avatar
We are not talking about cars Innomare
Old 11-09-2006, 01:36 PM   #29
Innomare
Senior Member
Innomare's Avatar
Unless they're amphibious of course
__________________
Old 11-09-2006, 06:34 PM   #30
YachtNews
YF News Associate
YachtNews's Avatar
LoL, alright then, i will let you through on that one then.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 01:03 AM.
Click for Horizon
Click for Burger
Click for Lurssen
Click for Christensen
Click for Shadow
Click for Heesen
