Click for YF Listing Service Click for JetForums Click for Walker Privacy Matters Click for Glendinning
Moving from fresh to salt water
Discussion in 'Technical Discussion' started by lucid484, Oct 5, 2006.
  1. lucid484
    lucid484 New Member
    Massachusetts
    Ok Ive always been on Salt water boats...But if you get a boat thats always been in fresh water is it possible to put it in saltwater???
  2. AMG
    Yes, I can´t see why you couldn´t? It may float a little higher, if it is a fast powerboat it may need a bigger prop. An inboard engine may need a freshwater cooling if it hasn´t and outboarders may need a flushvalve for freshwater. But basically boats are built for all kinds of water...:)
  3. lucid484
    lucid484 New Member
    Massachusetts
    Ok cool...because I plan on saving for a boat and possibly getting a 40' Chris Craft within a year and alot of them are in fresh water and notice the engines use fresh water cooling...but just wanted to make sure before i put it in salt water.
  4. AMG
    No problems then, just check the zink anodes, paint with antifouling in the bottom and go!
  5. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Also boats in freshwater typically have less metal/parts corrosion due to the lack of salt.
