Click for YF Listing Service Click for JetForums Click for Nordhavn Click for Westport Click for Ocean Alexander
Variable speed blowers
Discussion in 'HVAC' started by MYCaptainChris, Sep 30, 2006.
  1. MYCaptainChris
    MYCaptainChris Senior Member
    Melbourne Beach FL
    Currently my blowers are on or off. When on they blow like a hurricane which is great when at sea. While I'm on the dock having them on is just too loud both in the engine room and on the dock.
    Is there a simple way to make these 3 phase 208v blowers variable speed? The are on a switch which operates a solinoid so I was thinking maybe two speed would be easier???
    Any electical pros out there have suggestions?
  2. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    Frequency drives are the answer to your problem.
  3. wdrzal
    wdrzal Senior Member
    Ken is correct if its a single speed motor
    look for unused wires coming out of the motor .,some are multi speed but the correct wires need to be hooked up. there may be several wire unused and just capped off.
    There should be a wiring diagram on the motor plate that indicates the number of speeds the motor is.
    Am I correct in assuming these are direct drive?
    This is to everyone,when asking technical questions over the net its always best to post a few pictures of your equipment. Otherwise unless some one is familiar with that exact model , is hard to give answers,
    finally are the blower wheels clean and free from dust. Dust and dirt collects on the fins and can raise the db level significantly. Also too small of intake or exhaust ducts can raise the velocity also making them noisy.
  4. TSI AV
    TSI AV Senior Member
    Estonia
    Check out stamped labels on el. motors.
    You can make 2-speed version if there is Delta / Star option.
    But I did not understand Your sentence:
    " The are on a switch which operates a solinoid so I was thinking maybe two speed would be easier??? "
    Which solenoid is meant ?
    Rgds,
    Andrei
  5. Castlerock
    Castlerock Senior Member
    New England
    Chris,
    Here is a a link to a controler we have used in a factory application to control the speed of 3 phase motors. You can eliminate the solinoid and wire you control circuit into the controler. The controler allows you to set the RPM on a LCD display and is accurate to 1 RPM.
    http://www.atrump.com/Inverter/E9s.htm
  6. MYCaptainChris
    Melbourne Beach FL
    brilliant
    That looks like the sort of thing I'll be after.
    I just knew this forum would come up with something.
