Click for Trinity
Click for Shadow
Click for Benetti
Click for Moonen
Click for Christensen
Click for Heesen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Dimensions over and under water
Reply
Old 04-18-2007, 11:20 PM   #1
Leveller
Registered User
Leveller's Avatar
Hi all,
I would like to know what height and draught overall is planed (or expected)by a designer or shipyard for a 200' yacht (stlye like: Utopia, Siran, Tripleseven etc).
The use has to be for inland waterways as for Med and atlantic crossing on own keel. Examples:
- Trollhatta Canal (Sweden)
- Saimaa Canal (Russia / Finnland)
- Volga water system, to reach Moskow from Black Sea and from Baltic Sea.
Is it possible to construct a mast on fly which can be lowered inclusiv sat -domes and antenna?
Regards
Martin
Leveller is offline   Reply With Quote
Old 04-19-2007, 02:26 PM   #2
techmati
Senior Member
techmati's Avatar
Its possible to construct anything you wish but anyway already many river vessels have masts that can be lowered. Some even have wheelhouses which are on scissor lift and are lowered for going under bridges.
__________________
if it floats shoot it with a canon.....
techmati is offline   Reply With Quote
Old 04-19-2007, 06:06 PM   #3
Leveller
Registered User
Leveller's Avatar
Jep, I can see them here in Bremen everyday, those cargo vessels with a beauty of a VLCC. But they can't go even from Weser to Elbe by crossing just 20 nm of coast near waters. She has to look good if entering IYCA.
I think I have to specify my question.
When I remember correct, there is a hydraulic foremast on the Oceancos Constellation to have a better looking yacht or what ever. This is what I want, but not for the foremast, but for the main mast and parts of the sundeck construction. What about MCA Rules? Will they node and then call the people with the white coats or will they don't have a problem with lowering the main communication systems to pass bridges or looks? Anything on safty rules? Even the systems: Will they work during the process when they are lowered?
The other part of my question was to find out how high one deck or the examples I mentioned above are. I am lousy in guessing dimensions on photos. Is Utopia more 20 or 25 m high, or just 16? What height does a designer plans in for each deck, what for the top mast?
For me max dimension have to be:
l - 75,00 m (minimum about 70,00 m)
h - 16,00 m (inclusiv all antennas and top lights)
w - 11,10 m
d - 2,80 m
She should have three decks (or what ever to have space for owner-, 2 VIP- and 3 guest cabin, plus the normal lounges and extras) and has to cross the atlantic two times a year. Does a yacht with 2,80 draught will have seaworthyness problems in bad wheather in the atlantic or even on a normal crossing?
Aditional question: Will an automatic positioning system work on rivers too?
Kind Regards
Martin
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 10:21 PM.
Click for Quantum
Click for Trinity
Click for Lazzara
Click for ISA
Click for Westport
